93 accord ex check engine light
I have a 93 accord ex and it's had the check engine on since I got the car (about a year ago) I been driving the car ever since but I want to fix the problem any ideas what it can be? Car drives fine just has check engine and abs light on
You can use the self diagnostic procedure to get the codes from the ECU.
Here is a link to a thread covering the procedure.
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-check-codes-96-accord-2301560/
The DIY is for a 94-97 Accord, however the technique is the same, the location of the 2 pin connector is different. IIRC the 2 pin connector for the 90-93 Accord is found behind the plastic side panel in the passenger side footwell.
istabrak
Oct 28, 2009 01:14 PM
