99-00 si linkage/rear t bracket, ek b series mounts, & obd1or2 dizzy
I bought a b18b1 for my 97' dx
...have updated what I currently need, being...
94-01 integra OR 99-00 si shift linkage
oil dipstick that will work for b18b1
Thanks
Thanks
Pmed!
I bought a b18b1 for my 97' dx...trying to locate some parts while I save more money...
Seeking:
b series mounts for ek (driverside must be 3 bolt post)
obd1 or 2 distributor (have a jumper so either works)
I have some obd0 stuff I could trade and some other things laying around. Lemme know if you got this stuff.
Seeking:
Found a cheap distributor. He lives in Michigan. Not interested in any used parts unless the price is the used value. Thanks guys.
I got a obd1 dizzy too. Mint fresh. I got it directly from acura. Less than 2500miles on it. If your other one falls through let me know if your interested.
Actually yes. A fellow member here offered the si bracket for $35 shipped...can't beat that really. Also I located some obd1 distributors for $40 shipped, but still kinda seeking for an obd2 because my jumper is states away with a friend. Still looking for linkage & aftermarket engine mounts...
I have an OEM OBD2 distributor, but it won't be $40 for it...where you located? You can PM for price on dizzy...
quick search on eBay, where I sell most parts...
http://www.ebay.com/sch/Distributors...Condition=3000
The top mount bracket is the same from B and D. Just put a b16 in a 99 civic sedan. Only thing we had to change was rear t bracket. Everything else from D transferred over.
You have been PMed :]
Not longer looking for distributor, thanks though.
May get back to you on the linkage & bracket if we can work out a deal.
This will not work with my swap. Thank you though. I did find the proper dizzy ya'll :]
I disagree. I have an extra D-series 2post mount and it didn't bolt up to my B-series...?
I used a D series 2 post on a B16a2 swap in a 99 EK sedan. Bolted to motor bracket and mount no prob. Bought a 00 Si one to use and forgot it was in the truck and used the D series one. I had no prob with it at all.
Do you need the block piece or the bracket that has the holes in it that also bolts to the rubber mount.
