Honda CR-V & Element 2WD & 4WD Element & CR-V
AC blower stopped working
Old Aug 13, 2012 | 10:32 AM
clankfu's Avatar
Default AC blower stopped working
So I ran this self diagnostic that was posted in the forum:
A. turn the ignition switch off
B. press and hold both the recirculation and the rear window defrost switches
C. turn ignition switch on (II)
D. the diagnostic begins in about 15 seconds
after the self diagnostic any problems will be displayed as a series of blinks of the recirculation indicator. the pulses will repeat about every two seconds.
# blinks defect
none none
7 open in the air mix control motor circuit
8 short in the air mix control motor circuit
9 problem in the air mix control linkage, door, or motor
10 a short or open in the mode control motor circuit
11 problem in the mode control linkage, door, or motor
12 a problem in the blower motor circuit
13 a problem with the EEPROM in the heater control panel
14 (w/ac) open in the evaporator temperature sensor circuit
15 (w/ac) short in the evaporator temperature sensor circuit
I got 12 blinks. Does that mean it's most likely the blower motor resistor?
QuestMCoupe
May 17, 2012 10:39 AM
