D16y7 Vaccum leak??/idle problem
Old Aug 13, 2012 | 08:34 AM
david420's Avatar
Default D16y7 Vaccum leak??/idle problem
I have a stock d16y7 and I noticed today a whistling at the filter on my SRI.
I found out its sucking air in, so much i put a piece of card board on it and it was suctioned to my intake pipe with the filter off.
I dont know what this means, but when i block off the intake it idles at about 100-200 and with the filter at about 700. This is with no loads at operating temp, fans kicked in already.
Old Aug 13, 2012 | 08:36 AM
Former User's Avatar
Default Re: D16y7 Vaccum leak??/idle problem
Seal the leak.
What is the idle problem?
Old Aug 13, 2012 | 09:14 PM
david420's Avatar
Originally Posted by RonJ@HT
Seal the leak.
Should i get a new filter? Ive noticed the mesh is getting ruined because of the way it rests on the mount. Maybe this is causing a leak?
The idle problem is that sometimes it will idle low at 200 or 400 and this makes the car shake. And sometimes at around 7 where i set it. I dont want to raise it because then it would be too high when it is at 700. Idk why i have multiple idle speeds.
Old Aug 13, 2012 | 09:17 PM
What car? Stock?
Post pictures.
CEL codes?
Have you cleaned the IACV?
Old Aug 13, 2012 | 09:19 PM
david420's Avatar
Post pictures.
Old Aug 13, 2012 | 09:21 PM
What's behind the cardboard and where is the leak?
david420's Avatar
What car? Stock?
Post pictures.
CEL codes?
Car is stock, ej6 with a y7
I just threw p0505 the other day, after adjusting idle up, but adjusted my idle back down and it went away.
I have cleaned it before, not in months though. I am thinking its a vacuum problem, either my filter or my pcv valve.
Old Aug 13, 2012 | 09:25 PM
david420's Avatar
Behind the cardboard is a coupler type thing that I put my filter on.
I dont know if there is a leak. I just know that the cardboard was suctioned to the pipe. You have to pull it off with a small amount of force to remove it.
Old Aug 13, 2012 | 09:26 PM
What filter?
It's a good idea to replace the PCV valve but it's not likely to throw P0505.
Start by cleaning the IACV and then try again to adjust the idle speed using the service manual procedure.
Old Aug 13, 2012 | 09:29 PM
david420's Avatar
What filter?
Its a spectre, and like i said it is worn on the bottom from rubbing on the pass mount.
I know the reason for the P0505 was bc i adjusted the idle up. It happened soon after.
Ill try cleaning it again. All you do is turn it a half turn at a time after car has reached op temp and fans on right?
Really what i was worried about was that my intake was sucking in air at idle, is this normal?
Old Aug 13, 2012 | 09:30 PM
The engine pulls air through that opening, so I am puzzled as to why you would block it with cardboard. Explain.
And if you think the filter is clogged, then replace it. Am I missing something?
Old Aug 13, 2012 | 09:33 PM
david420's Avatar
I put the cardboard there so i could walk to the inside to see what the idle is when it is blocked off. It is about 100-200.
I didnt think it was clogged more like it has a leak. It makes a whistling sound at idle, slight different than the whistle it makes using throttle.
I know the intake is meant to pull air, but should it be pulling air at idle?
Old Aug 13, 2012 | 09:38 PM
I don't get it. It makes no sense. Why do you have cardboard blocking the air intake. If you remove the cardboard, does the idle return to normal. Of course the engine pulls air through the intake anytime the engine is turning.
Post pictures of the filter.
Where is this leak you're worried about? Mark it in the picture.
Old Aug 13, 2012 | 09:46 PM
david420's Avatar
I just did it kind of as an experiment to see what the idle would be if i did. Of course i dont drive around like that.
And yes when the cardboard is removed it returns back to around 700.
And i will post a picture of the filter in a few minutes.
Old Aug 13, 2012 | 09:59 PM
The idle speed is normal without the cardboard, right? So there's no idle problem.
And are you worried that some unfiltered air is leaking past the air filter?
Old Aug 13, 2012 | 10:08 PM
david420's Avatar
Well sometimes it idles normal. Sometimes it idles too low.
For example, ill stop at a light and my car will shake really bad and be idling at like 300. Then at another stop it well be back at 700.
My car also takes an extremely long time to get to normal idle at startup. Id say almost 5 minutes to drop from 1500 to 700, idk if this is normal, none of my other cars seemed to have this problem. Maybe cause ive always had a B and they have a FITV??
My main concern is why the hell is my idle different from stop to stop? I just have no idea what could casue it to be at 300 then 5 mintues later 700.
Old Aug 14, 2012 | 01:20 AM
Axatax's Avatar
^ Do what Ron said and change your PCV valve. It's $4 + the cost of an oil change. That filter needs replacement but that's not causing your idle issue.
Old Aug 14, 2012 | 06:23 AM
david420's Avatar
Yes i was planning on replacing the pcv, can that cause a sporadic idle?
Aguem2
Aug 10, 2013 10:05 AM
igotaprestent4u
Honda Civic (2001 - 2005)
Aug 21, 2009 09:21 AM
frostwhite_92
Jan 10, 2005 02:12 PM
hahnchen
Mar 11, 2004 04:13 AM
