Head Machined and every head bolt "creeking" when torquing
Old Aug 12, 2012 | 05:58 PM
RSSEXtype-sizzle's Avatar
Default Head Machined and every head bolt "creeking" when torquing
I've changed head gaskets out plenty of times, I had a head laying around my garage from an old project and it looked to be warped. I got it milled.
I purchased a block from a local junkyard that was from a good running civic that they already sold the head.
I bought new head gasket and dowel pins that go on block.
I set everything in place and on the first bolt going to 22lbs. I was getting creeking. I reinspected everything and tried again and still getting the noise. I cleaned and lubricated the bolts.
Could it be the bolts are stretched? Or was the head improperly milled?
block is d16y8 and the head is from a 99 EX (same block)
Thanks for your help this is very frustrating
Old Aug 12, 2012 | 06:05 PM
Dc4LsTeG's Avatar
EK9
Default Re: Head Machined and every head bolt "creeking" when torquing
Creeking is pretty normal when torquing head studs
Old Aug 12, 2012 | 06:51 PM
v8killaz's Avatar
next time lube the washers
Old Aug 12, 2012 | 07:04 PM
turbohatch96y7's Avatar
Yeah as long as there isn't much resistance when you put them in hand tight that creaking is normal.
Old Aug 12, 2012 | 09:46 PM
Mixmasta's Avatar
X2
Creeking is normal. I usually dip my head bolts in oil before installing to lube them up, just make sure you let most of the oil drip off before you actually install.
Day-DayC
May 18, 2006 08:51 PM
natzimus
Apr 27, 2006 06:04 AM
Turbo_y8
Feb 25, 2006 10:10 PM
nuc79
Aug 1, 2004 01:56 PM
simplypinoyy
May 20, 2004 11:31 PM
