Greddy TD04H-15G downpipe bolt size/thread
Old Aug 12, 2012 | 05:07 PM
Herro Panda's Avatar
Default Greddy TD04H-15G downpipe bolt size/thread
So i bought a used greddy kit, but it didnt come with the three bolts that connect the turbine outlet to the downpipe. I cant seem to find any specs about the kit and i nothings turned up on searches. If anyone knows what the bolt size/thread is for those, i would greatly appreciate it. I think its a 10mm but i went to lowes and they only had a m10x1.50 and it didnt go in at all (i think the diameter was right though).
Thanks!
Old Aug 13, 2012 | 07:18 AM
Hyper16-Johnny's Avatar
Default Re: Greddy TD04H-15G downpipe bolt size/thread
What's your location? Are they the bolts for elbow to turbo? If so they should 12mm bolts which are M8 x 1.25 bolts or studs.
Old Aug 13, 2012 | 08:56 AM
Cleveland. No, it the bolts that connect the elbow to the downpipe.
Old Aug 13, 2012 | 11:01 AM
I believe those are 14mm, M10 x 1.25. Damn you're in OH, was hoping you would be here in SoCal because there's a nuts and bolts store near my place called Cal Aero. Here's their info just in case http://www.calaerosupply.com/ goodluck!
P.S. My answers are based off of the Greddy TD05-18G not the TD04-15G, but they share the similar T25/T28 housing therefore should use the same bolts.
Old Aug 14, 2012 | 10:31 AM
dpetro1's Avatar
go to a different hardware store. lowes and home depot never seems to have automotive size bolts. go to an ACE or Truevalue, they have a much better selection.
invisible
Welding / Fabrication
Apr 12, 2009 08:26 AM
PA MATT
Mar 23, 2005 09:39 AM
d_mina
Sep 15, 2004 02:47 PM
JapSpec954
Aug 15, 2004 07:03 PM
