1996 ITR engine in EJ8 drive shaft question
Old Aug 12, 2012 | 02:54 PM
hybrid_ITR's Avatar
Default 1996 ITR engine in EJ8 drive shaft question
Long time reader first time poster
I've installed a 1996 B18C engine into my EJ8 over the weekend, using the hasport mount kit, went to install the drive shafts (axles) and the one attached to the intermediate shaft was a good 15mm too short from the back of the hub... the shafts I ordered originally were for a VTiR civic hatch from 1997, I've since taken them back to the shop hoping that 1997 Integra DC2 shafts will be right this time around...
The drivers side was also shorter...
Any ideas?
Thanks in advance
Old Aug 12, 2012 | 03:07 PM
JuggerNaut-CTR's Avatar
Default Re: 1996 ITR engine in EJ8 drive shaft question
Pull the axle. If the inner joint has a male end you need an axle from a '90 - '93 Integra, any model. If it has a female end you need an axle from a '94 - '01 Integra/'94 - '97 Del Sol Vtec/'99 - '00 Si
Old Aug 13, 2012 | 01:06 AM
rd91sib18c5r's Avatar
You need integra or 99/00 si axles and half shaft, you can use older integra ones just make
sure the half shaft matches the axle.
Old Aug 13, 2012 | 04:34 PM
hybrid_ITR's Avatar
I have the 1996 ITR half shaft, ordered the 1997 b18c integra shafts from a vtir (gsr), this should be suffice?
fcfguitarist
Dec 31, 2008 02:46 PM
SlammedEG6
Suspension & Brakes
Aug 29, 2008 03:14 AM
Mushvroom
Jun 8, 2006 06:45 AM
V8SHME8
25
Feb 18, 2005 10:13 PM
iridebiketrials
Jun 10, 2004 05:22 AM
