93' Del Sol - Won't start - Has fuel pressure and spark
First of all, I'd like to say I've been searching the forums and Google for a few hours and tried most of the basics. Here's the deal...
My battery died in my wife's 93' Del Sol. I tested the battery, it was bad, replaced the new one, and suddenly... the car won't start. It turns over great, all belts turning. It only sat for about a week with the dead battery but did get a jump in the parking lot and drove it home.
First, I checked all fuses, all look okay. Second, I placed a extra sparkplug in a pulled wire and turned it over, I get white/blueish spark. Third, I loosened the fuel line at the filter and turned the ignition to accessory, lots of fuel squirts out. Fourth, I turned the engine over for about 10sec and pulled the plugs, they were wet with fuel.
I've read this thread: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-civic-wont-start-has-spark-fuel-pump-primes-3053960/ which seems similar. But, this was a firing order issue. I have not pulled any wires or done anything to this car, just replaced the battery. It was my wife's daily driver until the battery died. For the belt to jump teeth in between it sitting in the garage and starting with a new battery seems unlikely (the belt is also new and I inspected the teeth).
Could someone please point me in the right direction for further troubleshooting? I really don't want to tow it to a shop. I do have a multimeter (cheap harbor freight). If the main relay was bad, would that stop pressure to the pump?, because I definitely have that.
Thanks so much!
Thanks so much!
Have the alternator checked. It could be the root cause of the battery dying in the first place. Also, it's almost never a bad idea to pull the main relay and check for cracked/dry solder joints on a car that old and, besides, checking the main relay only takes a few minutes.
thanks for reply guys. a few questions...
one, I pulled the upper timing cover. I see the "up" on the cam gear, but don't see any mark on the valve cover or head to match it up with. My engine is D15B7.
two, is there an easy way to test the alternator?
thanks again!
thanks again!
Mechanical Timing
First, make sure you're crank pulley is set to Top Dead Center. Put the car in neutral and turn the crank pulley (use a socket on the crank pulley bolt or a box wrench on the power steering pulley bolt) until the white mark (TDC mark) aligns with the little bullseye looking thing on the lower timing belt cover. The TDC mark on the crank pulley is maybe an inch or so to the right of 3 other colored marks (those are used for setting ignition timing so ignore them). Get a flashlight and use it exactly like a bullseye... Look down at your lower timing belt cover, close one eye, and line up the arrow, notch, and TDC mark. When all 3 of those things line up perfectly, your crank pulley is set to TDC.
For your camshaft pulley, "UP" should obviously be pointing up but you should also have three groove markings on it. Two should be at the 3 o'clock and 9 o'clock positions, dead even with the top edges of your cylinder head. The third mark should be at about the 7 o'clock position, slightly (i'm talking like 1mm or so) to the left of the little plastic arrow on the inner timing cover plate.
Use the pic Ron posted above for reference. It's straight out of the service manual.
Battery/Alternator
Since you already have a multimeter check out this youtube vid for how to check your battery/alternator:
http://www.youtube.com/watch?v=FTGz0...feature=fvwrel
It'll explain it better than I ever could here.
Battery/Alternator
OP, has the timing belt been removed from the cam pulley for any reason recently?
Also, it's probably a good idea to check all 4 plug wires for spark. Just because one is sparking doesn't mean they all are.
You're clearly are not very familiar with our Civics. If you'd like me to explain, PM me. Let's not clutter the OP's thread with our disagreement.
OP, please do check the mechanical timing as described above. If that turns out to be correct, I'm sure Ron here will point you in the right direction...
Borrow another ECU and swap it out.
This is a common problem - moisture/condensation effects the ECU circuit board and you will get a crank but no start especially during rainy damp conditions.
Del Sol's especially 93's like mine they leak plus the ECU is now 19 years old.
Curlybandit
Aug 10, 2013 04:19 PM
mooney8289
13
Aug 3, 2013 12:54 AM
Aggression
Oct 13, 2012 08:22 AM
asletclark
16
Sep 5, 2012 04:21 AM
marjus
Jul 8, 2012 06:05 PM
