91 accord tcm compatibility
Old Aug 12, 2012 | 05:21 AM
j.deleon.jc's Avatar
Icon6 91 accord tcm compatibility
Hello everyone, I have a 91 accord lx wagon with 142k miles on it. The transmission control module is crapping out on me and needs to be replaced. I've looked for an exact replacement at the local junkyards in my area but can't find one.
So, do any of you know if any other TCMs are compatible with my car? I didn't want to go through the whole process before coming on here and asking, especially since I have a wagon and some parts are only for wagons. I've read on another thread that EX TCMs won't work on LXs. Is that true, and can I use the TCM from any other 90-93 accord?
the engine is an f22a1, and the serial number on mine is 28100-PXO-A12-M1
Old Aug 12, 2012 | 07:54 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 91 accord tcm compatibility
Can you solder or know of anyone who can?
The resistors and capacitors are known to burn up on these TCUs.
Click on the 'H4A' link in my sig for info regarding how to R&R the TCU.
Old Aug 12, 2012 | 08:17 AM
Bad_dude's Avatar
You don't need it to be exact, you just need it to be from 90-93. I knew about this problem, so 3 months ago, I pulled the TCM and soldered in better brand and a little higher capacity capacitors. Don't wait until it fails then you have to solder in the resistors which are hard to put on as they are smaller.
Old Aug 12, 2012 | 09:25 AM
10thcb7's Avatar
i used a tcu from a 94-95 ex. not sure the difference between ex or dx in the cd5 accords but along with an auto p12 that bastard shifted right at red line with the gas at wot. BUT THE D4 DID BLINK but it never ****ed any thing up ... food for thought
Old Aug 12, 2012 | 10:03 AM
jdmcertified909's Avatar
A EX TCM WILL WORK ON A LX. I JUST DID THAT TO MINE. I REMOVED MY LX ECU TO MY EX TO RULE OUT POSSIBLE BAD TCM ON MY EX AND THE EX TCM IS IN MY LX RUNNING PERFECT NO CHECK ENGINE LIGHTS NO D4 FLASHING OR ANYTHING SO THE EX TCM WILL WORK ON THE LX
Old Aug 12, 2012 | 11:51 AM
10thcb7's Avatar
at the junkyard i had two options both from an ex. the tcu i chose was smaller and golden in color idk just what i used on my CB7 back when automatic
808DA
Mar 17, 2009 03:47 PM
ajth87
Mar 9, 2006 02:10 PM
gumbysix
Acura TL, RL & ZDX
Sep 10, 2005 11:31 AM
JRhabbit
Nov 14, 2004 09:53 AM
