K20Z3 gear box into K20A3
Old Aug 11, 2012 | 09:27 PM
SiK20A3's Avatar
Default K20Z3 gear box into K20A3
Any one knows if a gear box ( 4.78 ratio )from K20Z3 can works well in a EP3 with K20A3 engine???
Old Aug 11, 2012 | 10:13 PM
doood's Avatar
been there done that
Default Re: K20Z3 gear box into K20A3
You need to swap shift mechanisms
Old Aug 11, 2012 | 10:25 PM
poeticfinesse21's Avatar
Yes it will work, the shorter gear ratios and LSD will really wake up the stock K20A3. You have 2 options to make it work on your EP3.
Swap the guts into a K20A3/A2 trans bellhousing:
http://www.k20a.org/forum/showthread.php?t=21945
Or modify the K20Z3 trans bellhousing to accept the EP3 speed sensor:
http://www.k20a.org/forum/showthread.php?t=40933
You will need the shifter mechanism from a K20A2 trans or modify your EP3 shifter to be able to shift into all 6 gears and reverse for both options, you cannot use the K20Z3 shifter mechanism:
http://www.k20a.org/forum/showthread.php?p=423546
Old Aug 12, 2012 | 06:03 PM
SiK20A3's Avatar
ok thanks for the info
Yangpho
Aug 20, 2015 10:48 PM
egk20trubo
K Series
Aug 19, 2014 06:21 AM
pete332
Transmission & Drivetrain
Jan 14, 2013 12:46 PM
s4yama
Apr 28, 2011 02:04 PM
Gunns
Jul 7, 2009 08:38 PM
