swapping hx spindals with si spindals
Need to.swap out spindals. so my b.series.score will fit tried finding it.in the web but.couldn't find. out how you swap the spokesman if some one knows a thread that show how to do it plz post.on here thank.you
just swap the whole knuckle.. you need to remove the brake caliper, remove the driveshafts, unbolt the steering rack end links, unbolt the lower and upper ball joints, and swap in the new knuckle. you will also want to keep your rotors, so take them off and put them on the new knuckles.
Has to be a knuckle dat was with a b series engine so ur b series axle can fit in so if its an si and had a b16 yea but u might need a camber kit after if knuckle is to big
Posted from Honda-tech.com App for Android
DX or Si will work. Either one, your choice, just remove the dust ring so the B-series axle doesn't bind.
meanshyguy
Jun 5, 2010 09:32 AM
CRX A4
Mar 4, 2003 09:08 AM
