Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Honda A/C Gurus needed!
Old Aug 11, 2012 | 04:15 PM
joeldaugherty's Avatar
Icon3 Honda A/C Gurus needed!
Ok guys ... 2003 Accord EX, A/C blower isn't working. HVAC controls light up and I can hear the vents moving when I switch setting. Compressor does not engage. The blower engages for like a second when ignition switch is in II position. Ran the self-diagnostic and it resulted in "N" - circuit problem (duh).
hot-wired blower, it works great ... check
tried new resistor, not the problem ... check
under dash fuses ... check
relays and fuses in under hood fuse box ... check
I don't know what else to check. Ideas?
Thanks!
Old Aug 11, 2012 | 05:13 PM
ekb16's Avatar
Default Re: Honda A/C Gurus needed!
possibly compressor clutch coil
Old Aug 22, 2012 | 10:44 PM
slowcivic2k's Avatar
Thanks!
Power supply to the blower is the fault. If you hot wired the blower using the blowers ground point, and then a wire off the battery, that is the only cause it could. If you created your own ground when you hotwired, the ground could be at fault too.
Try rocking the ignition switch when the blower stops working. My car has this problem when its colder. If that doesn't yield something interesting, you will need to track back from the blower to find out where the power is dropping out.
Accords around that year range have problems with the control head losing power internally, but the exact opposite occurs, the blower works on any speed, but the vent controls and a/c control will not light up or function. It is a possibility, but I've never seen it present that way.
Carlos Cruz
Jul 17, 2017 05:02 AM
jreyes16vmz
Apr 23, 2015 07:35 PM
soupE__
Jan 16, 2009 01:51 PM
kingpin56788
Nov 26, 2004 04:55 PM
StinkyTofu
Jun 29, 2003 01:52 PM
