Front Bumper Replacement - What part is this?
I had an after market fiberglass front bumper on my Del Sol for a long time. I just finished doing a turbo conversion and I needed to buy a stock front end in order to fit the FMIC.
The side mounting points are all torn up, I had been using zip-ties (ghetto I know) to hold on the fiberglass bumper, but the stock replacement is much stiffer and needs to be mounted securely so I need to repair/replace the stock mounting points.
I've been looking through online parts diagrams and can't figure out what I would need to replace this:
Over a hundred view and no one knows? Is that part of the fender or a separate piece that can be replaced?
The metal is so thin and weak I can't believe no one else has had to deal with this issue.
looks like it would be a type of headlight bracket... its a retarded thin metal that the headlight would sit against, more for alignment purposes i would suppose.
look into that
look into that
This is the part I'm referring to:
The hole is where the side bolt for the bumper goes through. It's bent down in this pic. I'm thinking it's just part of the fender that has torn.
slamdunkcivic
Oct 28, 2004 11:21 PM
ca_delsol
Oct 28, 2004 08:31 AM
