Need some help with a code 3
Old Aug 11, 2012 | 03:04 PM
codybuRr's Avatar
Default Need some help with a code 3
So i keep getting this code 3 everytime my car starts up cold.
I've tried changing ecu's to known good ones, 4 different map senors that are good as well.
I'm at my whits end.
I changed the o2 this morning thinking maybe that could potentially fix that.
I changed all the vacuum hoses as well thinking maybe there was a leak.
I can't find any. The sensor plug was also checked for continuity and works fine.
After the car heats up and I start it again at a light or stop sign, it makes the code go away and runs normal.
WHAT DO I DO?
I have an odb0 LS
Old Aug 12, 2012 | 01:04 AM
codybuRr's Avatar
Default Re: Need some help with a code 3
bump
Old Aug 12, 2012 | 12:39 PM
codybuRr's Avatar
Old Aug 12, 2012 | 12:48 PM
Navy_Kyle's Avatar
code 3 is the map sensor, try a known working one and see what happens even if yours reads that it is working just try it and see what happens
Old Aug 12, 2012 | 12:51 PM
codybuRr's Avatar
I've tried 4 different ones
Old Aug 13, 2012 | 06:59 AM
codybuRr's Avatar
need halp
Old Aug 14, 2012 | 06:48 PM
Former User's Avatar
Code 3 is an electrical problem in the MAP sensor circuit. Start by voltage and Ohm testing the three wires.
d_boi_swag
Jul 5, 2009 12:14 PM
saver
Mar 28, 2006 10:19 PM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
Used2beAb16
May 15, 2005 08:12 AM
k4ff1n3
Sep 28, 2002 12:15 PM
