1994 accord ex shakes badly
hey i just finish putting back together my 94 ex....and when i start it it runs fine..but when in gear like reverse or any of the drives...it starts shaking badly...unless i press on the gas then the shaking seems to die down a little....now im not to positive i lined up the balance shaft belt correctly i think i might of been off just a little could this be a problem?
Off the gas it shakes, and on the gas it seems to go away. Sounds like you broke an Engine Mount. Pretty Common to break them.... engine is still supported, mounts act as stabilizers...
Have someone step on the gas in neutral, and check to see if the engine torques/twists a certain way. Simple test.
Other shaking could be many things. Start there.
im just trying to get it fixed to sell it now since i was given a newer truck with way less miles lol
