DOHC ZC help
Old Aug 11, 2012 | 05:25 AM
sleepingciv's Avatar
Default DOHC ZC help
Well im lost on this car
fast run down of the prob
dohc zc eagle rod, vitara pistons, 6.55:1 compression
dsm red top injectors, oem fpr, all new parts, litterly not even a mile on the motor yet.
when it starts it seems fine a little tiny choppy. after a min or so it just takes a poo and nothing
all the timing marks are like they are supposed to be also
Old Aug 11, 2012 | 06:38 AM
TearSDMF89dx's Avatar
Default Re: DOHC ZC help
have you tried stepping the idle up ....are you running a stock ecu? ....does the motor have an iacv on it? ....any vacuum leaks? ...with that low of a comp. ratio i assume you're running boost are your charge pipes leaking? ....what kind of map sensor do you have? is it hooked up?
Old Aug 11, 2012 | 07:25 AM
havent touched the idle yet
its a chipped pm6 with the old tune for stock internals< im guessing i need a new basemap to run properish
yes iacv
no vac leaks that i can see or hear
yes boosted and pipes all tight
stock map sensor on the firewall yes hooked up
Old Aug 11, 2012 | 07:52 AM
it sounds like a tune would be a good idea ...with that low of a cr its hard for the motor to idle on a stock basemap
Old Aug 11, 2012 | 08:31 AM
ya i know getting with my guy about that. i have a tune now but its for the stock internals
thanks for help
Old Aug 11, 2012 | 04:47 PM
Charlie Moua's Avatar
convert to obd1 and get tune.
also 6cr must run like a turtle out before boost.
CRXguy_88
Sep 23, 2010 06:11 AM
90crxdohczc
27
Apr 14, 2006 03:55 PM
PTR1
Aug 23, 2003 01:55 PM
