Gsr turbo help!
Ok i recently bought a Dc2 Fully built gsr, its got a mild build to it, only things that are stock is the crankshaft and rods and not sleeved, but anyways it has CTR replica 11.5:1 81.5mm Pistons and i plan on going boost but i heard its not safe to boost on high compression pistons, so what kind of pistons should i buy and what compression ratio, i dont plan on sleeving so im only looking for 300-400hp for my dd.
also i have buddly club spec 3 cams. I also heard i need to change them to some turbo cams, what brand of turbo cams should i go to.
And i know i have to upgrade my injectors to bigger than rc 370cc's. what kind of injectors should i buy?
But my main question is what else should i upgrade for shure when i go boost. I really am on a tight budget but those 3 things i just listed i dont care if there sorta pricey bc there the most important. The turbo kit im getting is from dkgoodrich and its the 1600 stage 1 kit. ( ill post links to my car and the turbo kit at the end )
Just need some imput on some things
Dkgoodrich
http://www.dkgoodrich.com/turbokitspecial.htm
My car
http://www.mautofied.com/1994-Honda-...ing/100507834/
Dkgoodrich
My car
Get a kit from Greg at Go autowerks, he is the man and makes some good stuff. Just get some OEM cams as they are good till like 500 whp unless your going for braging rights. Your motor isnt built, it just has higher compression pistons. Sell your cams and other junk and get Eagle rods, Aries pistons.. Stock rods "can" handle about 500whp on a race motor but for daily driver I wouldnt go past 320 to 350 whp..
