ls vtec will not start
Who the fack changed my title?!
Swapped over a Gsr head, stock fuel system from the ls I e injectors, pump rail etc. I do not have the vacuum hose from the stock fuel pressure regulator hooked up at the moment. Running an obd1 Gsr dizzy repinned to obd2 clip. Timing is spot on. Took the crank pulley off, aligned it up to the mark, used to pins on the cams to help line them up and still nothing works. When I turn the car in it is priming fuel. But the line I have on the car is linked at the return. The car turns on for a split second then dies . Any ideas?
chadwick16
Sep 27, 2005 03:33 PM
