acefighter028: 1999 Honda Civic Si
Picked this up were i work. Was a trade in. Dont know what to say, so pics.
Yes. The mileage is correct.
Yes, i am going to modify it. If you want it to stay stock feel free to mail me $200,000 and the car can be yours
Plans
Interior:
Type R red stitched boot
OEM Honda weighted shift ****
zxilon protective coating
Drivetrain:
Buddy club short shifter
Polyerthane shifter bushings
Exterior:
remove dents
xzilon protective coating
OEM sunroof visor
OEM window visors
rear window visor
Engine:
red powdercoated Skunk 2 intake manifold
JDM red type R valve cover
HKS Super Hybrid Filter Element
larger throttle body
cooling:
Password JDM dry carbon fiber cooling plate
Buddy club radiator cap
red samco silicone hoeses
Koyo radiator
Suspension:
coilovers undecided
Buddy club lower ball joints
Buddy club front camber kit
Buddy club rear camber kit
Blox Neo chrome lower control arms
ASR NEO Chrome rear subframe brace
Beaks lower arm bar with bolt spacers for use with ASR subframe brace
ASR 24mm rear sway bar kit
Polyerthane bushings
Benen tripod Front strut tower bar in Chrome
Wheels/tires/brakes:
Wheels undecided
Neo chrome lug nuts
Brembo OEM replacement rotors
Hawk brake pads
Exhaust:
undecided catback
factory cat
exhaust manifold undecided
Oils/fluids:
Enos 5w-30 Synthetic motor oil
Hamp oil filter
OEM Honda coolant
OEM Honda brake fluid
OEM Honda power steering fluid
OEM Honda transmission fluid
Plans
Interior:
Drivetrain:
Exterior:
remove dents
OEM sunroof visor
OEM window visors
rear window visor
Engine:
cooling:
Koyo radiator
Suspension:
coilovers undecided
Wheels undecided
Neo chrome lug nuts
Hawk brake pads
Exhaust:
undecided catback
factory cat
Oils/fluids:
Hamp oil filter
OEM Honda coolant
Thats what i thought when it came in to be detailed. I went to the sales department right then and signed the papers.
1 owner. All maintenance records from 99 till 2012. All maintenance done at Honda except for the midas muffler
They wanted to put it on the sales floor just to show. But i wanted it.
Thanks, man.
Thanks, man.
Got Greddy SUS header today for 160. It had some ugly black paint on it. Im repainting it "aluminum". Pics later. Im not installing anything untill i have my entire exhaust ready.
How i got it
Aircraft remover.
Dosent look great underneath but for 160 you get function and not form. Im fine with that.
After a few coats of "aluminum" Rust-o-leom 2000 degree ceramic paint I have a Greddy SUS ceramic coated header.
I realize my room is nasty.
How i got it
Aircraft remover.
good find man, i found my ek hatch at my work for a steal price with 55k on it, there wasnt a 2nd thought if i wanted it, good luck on the build in for this!
I'm not a fan of Skunk2 parts for several reasons but I made more power from an AEBS manifold than a new gen skank2. And it's significantly cheaper. I'd also recommend D2 or function form coilovers. I've been using both since 2007 with no issues.
