86 Civic engine swap
Old Oct 15, 2002 | 08:30 PM
toughguy327's Avatar
Default 86 Civic engine swap
I want to swap a bigger motor into my 86 DX hatchback. Has anyone done this? What engine was used and what model did the donor engine come from? How hard was it? On a scale of 1 to 10 (1 being the easiest, 10 the hardest)? Any help is appreciated. Thanks in advance
Old Oct 15, 2002 | 10:09 PM
HF2ZC's Avatar
Default Re: 86 Civic engine swap (toughguy327)
You can use an 86 - 89 Acura Integra engine, but switching over to fuel injection will be difficult. For this swap you also will need the Integra transaxle and some other parts (I can't remeber what). Running the Integra engine with sidedraft carbs would probably be the easiest to set up.
Old Oct 15, 2002 | 10:23 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: 86 Civic engine swap (HF2ZC)
whatever swap you do in that car, the difficulty level will be a 10. because your car is carburated, and switching to fuel injections requires EVERYTHING to be swapped over. PITA. you're better off selling the DX and buying an Si.
Old Oct 16, 2002 | 06:32 AM
xci_ed6's Avatar
You could put carbs on a D16A1, it will then drop in. It would be about a 4, maybe a 6 if you try to keep the emmisions stuff.
-D
Old Oct 16, 2002 | 09:57 AM
frank5079's Avatar
You could check this out:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1869081678
Frank
Old Oct 16, 2002 | 10:03 AM
spiceisler's Avatar
Default Re: 86 Civic engine swap (frank5079)
A B16 will also fit with mods. SCC did an article on it also I think Hasport has mounts for it.
Old Oct 16, 2002 | 04:05 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: 86 Civic engine swap (clean90Si)
if you find a carbed B16, then yeah. and what are the chances of that happening...0.
he's carbed! if he swaps, it MUST be a carbed motor. unless he converts to FI.
didn't i already say this...
90DXFlorida
Sep 1, 2018 09:27 PM
cody_sandlin
Oct 22, 2011 01:26 PM
EF_generation
Oct 1, 2004 01:24 PM
AgentWd40
Sep 20, 2004 03:24 PM
AgentWd40
Sep 20, 2004 12:12 AM
