A/C issues not cold anymore after refilling not too long ago. why???
Old Aug 9, 2012 | 04:27 PM
mynameizstitch's Avatar
Default A/C issues not cold anymore after refilling not too long ago. why???
ok i got a 1990 civic sedan. just got the a/c refilled at a shop about 3 months ago and they inspected it there and everything was good. already converted to r134, no leaks, belts good, no wierd noise or anything like that and was real cold after the refill for about 3 months. the last 2 days the a/c just doesnt get really cold anymore why is that? is it because of the compressor?
Old Aug 9, 2012 | 05:19 PM
zrickety's Avatar
Default Re: A/C issues not cold anymore after refilling not too long ago. why???
Probably leaked out. Just because it was ok then doesn't mean it's still full.
Old Aug 9, 2012 | 05:26 PM
v4lu3s's Avatar
RTFM
what did the shop that did the work say?
Old Aug 9, 2012 | 08:36 PM
they said everything was good. pressure and stuff was good. no leaks. now when i turn it out its kinda cold but not cold like it was before.
Old Aug 10, 2012 | 06:38 AM
zrickety's Avatar
It's leaking out or both of your fans are not working. Does it get colder on the highway? Is it getting a little warmer everyday?
Old Aug 10, 2012 | 03:10 PM
both fans are still working. now it seems like its barely even cold now
Old Aug 10, 2012 | 03:15 PM
zrickety's Avatar
It's obviously leaking. Try to charge it again and see if gets colder.
Old Aug 10, 2012 | 07:02 PM
v4lu3s's Avatar
RTFM
so you have ac that blows warm and the shop told you it works?
Old Aug 10, 2012 | 07:26 PM
Hidenplanvew's Avatar
They should of put it under a vac for 10+ min... Im going to bet they didnt
Old Aug 11, 2012 | 06:40 AM
KINGVEM^^ED6's Avatar
Take it back n complain u payed n they didn't solve ur problem
Old Aug 11, 2012 | 08:46 AM
btrux0611's Avatar
Take stop leak cans do actually work I think
Old Aug 12, 2012 | 10:50 AM
sstupid's Avatar
10 Year Member
You need to put a set of manifold gauges on it before you decide if you have a leak. If you do have a leak, your high-pressure side will be about equal to the low pressure side. At 85 degrees air temp, you should be at about 35 psi on the low side and 250 psi on the high side. Somewhere around there, anyway. The warm air could be caused by a lot of things. Your heater door could even be open. Maybe your cable for the air mix broke. There are a lot of things to check. If you have a remanufactured compressor, those things go out all the time, too.
Is your clutch cycling on and off? Is it cycling on and off in quick succession?
Old Aug 13, 2012 | 08:13 PM
not sure when you say if my clutch is cycling on or off.
Old Aug 13, 2012 | 09:11 PM
Former User's Avatar
Verify that the refrigerant is low by hooking up a manifold gauge set. If so, add up to a can of r134a containing a leak detecting dye. Where the dye appears is where the refrigerant is leaking.
Never add refrigerant containing anything advertized to stop leaks. It creates more problems than it helps.
Old Aug 14, 2012 | 07:09 PM
ok i will check more into that when i have time to see if there is any leaks
aneelmaan
Jun 9, 2014 07:22 PM
zx2gotboost
Jul 1, 2011 12:10 PM
black cx
May 15, 2008 09:30 PM
crxaddikt
Sep 20, 2005 12:34 PM
mnbv
Sep 6, 2004 03:43 PM
