F22A 5SP Gear Issue
Old Aug 9, 2012 | 08:34 AM
10thcb7's Avatar
Default F22A 5SP Gear Issue
Went to start the car, pressed clutch peddle , selected first gear, turned the ignition on, engine started, I released the clutch peddle and nothing!
I can shift through 1-5 R and not a single **** is given by the transmission. I dont get it? Even if the clutch was shot should'nt the transmission grind when you try to engage it into a gear with out using the clutch. ESPECIALLY first. ?
Help, advice and thoughts are welcome thanks bros.
Old Aug 9, 2012 | 12:28 PM
paintb91's Avatar
Default Re: F22A 5SP Gear Issue
Have u checked the shift linkage?
Old Aug 9, 2012 | 05:59 PM
Hidenplanvew's Avatar
possible compleat clutch failure and nothing is catching anymore aka input shaft isnt turning thats why you can put it in gear like if the engine were off..
Old Aug 10, 2012 | 02:36 PM
10thcb7's Avatar
im amost 100% its complete clutch failure that may have been provoked by a bad clutch cylinder
Old Aug 10, 2012 | 04:29 PM
Atleast its not to bad to do in a garage.. Put a 10lbs flywheel in while in there... Total night and day diffrence. Also do a Rear main since the trans is out... Exedy or comp clutch only
You could also do a h22/h23 trans swap or h22 with a f22 5th gear... Lots of options
Old Aug 10, 2012 | 06:28 PM
10thcb7's Avatar
so you think I could do this with 4 jack stands. 2 jacks and some hand tools? ?!?!?!?
Old Aug 10, 2012 | 06:55 PM
You can, just make sure to get a breaker bar from like Harbor frieght (24") and a 1/2 to 3/8 adapter then have 17mm, 14mm, 12mm, 10mm sockets.. Deepwell and standerd... getting the flywheel off should be fun tho so you need to figure some way to keep the crank from turning over. I use a screw driver to hold to hold the flywheel... Flywheel tq is 76ftlbs and I dont remember off hand what pressure plate tq is but I think its something like 16ft lbs. Yes you can do it on jack stands, you only need to get the front off the ground use one jack stand under the oil pan with a block of wood to keep the motor from just hanging. Anything else just pm me. Oh use lock tight blue on the flywheel bolts and pressure plate bolts.
Old Aug 11, 2012 | 08:33 AM
10thcb7's Avatar
Im not entirely mechanically inclined I've done steering brake and suspension Labor along with distributor and alternator replacements so as you can see I can do a tune up on my car but I've never done a clutch job.
Ill PM you bro.
Oh and i went to download the helms manual from spooner tuner and lo and be hold the govnt take down of megaupload ****ed me good
Old Jan 19, 2013 | 11:17 PM
10thcb7's Avatar
it ended up being the clutch, had it installed. -_- got fucked outta cash what an *******
Old Feb 4, 2013 | 07:38 PM
10thcb7's Avatar
I couldnt spend money on the car it was one of those dudes that charges more if he sees you can spend money on parts. Douche. Any way now I can do it myself. Should I lighten the flywheel from 19.5 from OE replacement weight to 14.5-15.5 weight?
So you suggest Excedy over other brands ? Why? A a guy I knew also preferred on his B16A as OE replacement. The question is, is it lighter than a OE replacement?
DulinDragons
Sep 29, 2015 01:09 AM
TheSickestDC2
Dec 20, 2009 06:44 PM
Chief Brody
Aug 4, 2004 09:28 PM
Kevins2k
Jun 11, 2003 10:56 PM
FlipboiGSR
Sep 12, 2001 09:07 PM
