ls vtec swap ??????
Old Aug 9, 2012 | 12:47 AM
kimbler99's Avatar
Default ls vtec swap ??????
I got a 99 coupe that had a y7 in it and i'm swapping in a b18a1 with a b16a2 head. I know i can use my y7 harness but i'm wondering what all i need to extend and change to make it work. i'm new to swapping and any help would be great. thanks
Old Aug 9, 2012 | 01:30 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: ls vtec swap ??????
-add VTEC and knock* wiring
-convert IACV from 3 to 2 wire
-extend secondary 02*
-CKF bypass*
-some misc other extensions
*if you convert to OBD1 using a P28 you won't have to do any of these
Old Aug 9, 2012 | 01:45 AM
kimbler99's Avatar
i do plan on going obd1 also also i believe the plug for the dizzy is different. do i just swap plugs?
Old Aug 9, 2012 | 05:13 AM
nealnanoHX's Avatar
-CKF bypass*
Yep but even if you go OBD1 you will still need to do the 3-2 wire IACV and a O2 extension. The rest of it is just like doing any other B series swap.
Old Aug 9, 2012 | 05:30 AM
Technical Hero
Just to clarify if you go OBD1 you won't have to extend the 2nd 02 as the OBD1 ECUs don't use a secondary.
Old Aug 9, 2012 | 06:30 AM
kyden's Avatar
you'll have to extend the first o2 sensor wiring with any b series swap.
Old Aug 12, 2012 | 12:41 AM
kimbler99's Avatar
thanks guys. it don't sound like it will be to hard.
oldschoollove
14
Oct 1, 2009 03:01 AM
slammedz6ef
Dec 31, 2007 04:13 AM
aznwash3wboi
Aug 30, 2005 05:02 AM
^Sammy]!.
May 9, 2004 04:09 PM
CanadaCivic
Aug 13, 2002 03:05 AM
