Prelude ride height help!
Old Aug 8, 2012 | 06:10 PM
PreClude's Avatar
Default Prelude ride height help!
I'm not sure what the stock ride height is for our 5th gens, but almost every car I've owned you want the ride slightly lower in the front and not the back. Unless this isn't true on the Preludes, my fear is that the previous owner lowered the rears on my car more than the front. Either that, or he swapped the GC coilovers front-to-back (someone told me this was a "cool" thing to do back in the day?)... that might explain the difference in ride height.
To me it just looks awkward to see my back sagging down so much. Almost like I'm moving and I stuffed everything I own in the trunk, ya know? Is this normal? I know I'm in need of new shocks, but the Ground Control coilovers are good. It shouldn't be sagging this much, should it?
I'm not sure what kind of measurements can help out in this, but I measured from the top of the rim to the beginning of the wheel well. As you can see there's quite a big difference from my front to rear...
Old Aug 8, 2012 | 07:16 PM
n0n_Vtec's Avatar
Default Re: Prelude ride height help!
Get coil overs
Old Aug 8, 2012 | 07:29 PM
PreClude's Avatar
Originally Posted by n0n_Vtec
Get coil overs
Um, I have coilovers... well, the hybrid Ground Control GCs. Not sure that's the problem. They are adjustable in height so either the back was adjusted lower, someone swapped the rears and fronts, or that's how a stock Prelude sits with the rear lower than the front??
Old Aug 8, 2012 | 07:34 PM
dbd6604's Avatar
I would just raise the back 1 cm and lower the front 1 cm. This is almost exactly how my car sits now and it bugs me too haha.
Old Aug 9, 2012 | 02:33 AM
schmitty915's Avatar
You have coilovers, just raise the rear. Not sure if you don't understand how they work or what, but this is a very simple fix.
Jack the rear of the car up.
Spin the perch up.
Make sure it's even on both sides.
Old Aug 9, 2012 | 04:00 AM
BergRacing21's Avatar
just raise the rear a little this seems to happen with like all coilover sets for the 4th gens and 5th gens you can lower the back more than the fronts. It's normal the guy didn't mix anything up. Just raise the rears a bit.
Old Aug 9, 2012 | 05:56 AM
dbd6604's Avatar
Just to help since you haven't done this before: when adjusting the ride height, jack up the whole rear end of the car, not just one side.
Old Aug 9, 2012 | 06:04 PM
PreClude's Avatar
Are the settings for height adjustment on the coilovers pre-set? I mean, are there designated 1/4" turns or clicks or anything like that so I am not like 1/8" higher on one side than the other? I know there has to be a trick here
Old Aug 9, 2012 | 07:56 PM
dbd6604's Avatar
There are no presets. Just adjust one side to where you like it, then measure from the bottom of the collar to the bottom of the sleeve. Then do the other side and measure to make sure they are even. It ain't hard.
f22_Strike
May 28, 2011 12:45 PM
wle05
Aug 15, 2008 10:46 PM
Understeer
Oct 28, 2003 10:25 AM
ruiner17
Feb 21, 2002 09:54 AM
digitalspice
Nov 27, 2001 07:11 PM
