First time at the drag strip...
Took my new hybrid to the drag strip tonight. Got 7 runs in. Mods: 92 DX hatch full interior, 95 JDM GSR engine, 12.5:1 CR, eagle rods, balanced, JUN flywheel, 6-puck metallic clutch, AEM CAI, custom drag header w\2.5" collector, full 2.5" exhaust, MSD SCI ignition, Dunlop SP5000 Sports at 25psi, stock head.
Malfunctions: MIL at 3-4 shift cause car to run in limp mode therefore redlining at 7000rpm on every run... No 4th+ gear VTEC... Untuned... burning oil and running rich as hell. Notice the incredible lack of acceleration between the 1\8 mile mark and the trap...
Best time was a 14.46@92. That is an uncorrected time at about 1000 above sea level.
2.211 60' didn't seem too bad to me, considering that this is my first time at the track with this car, and 2nd time ever. Any comments\advice is greatly welcome!
Thanks,
-Nick-
[Modified by B19CivicHB, 12:12 AM 10/16/2002]
Thanks,
-Nick-
get all the bugs worked out...should be able to get her to pull harder at the top end of the track...maybe high 13's on streets...what kinda gas you run for 12.5:1? is your car daily driven? good job for your second time ever
wow i have less stuff done to my motor i run a 14.1...... all i got is b18c1 , skunk man, msd coil, i/h/e
4th gear makes up the last 4 seconds or so of my run. I had to shift from 3rd to 5th everytime due to "limp mode". I thought a 14.4 wasnt bad considering what i was dealing with.
stock ecu... Im in the process of getting my head fully built by Rocket from this board. After that I will have it tuned with a Stage 3 Hondata.
The runs were at Dragway 42 near Wooster, Ohio. www.dragway42.com [Modified by B19CivicHB, 10:10 AM 10/16/2002]
I would not run my own car at the strip with those types of problems, but it's your car.
The list of problems was about as long as the list of mods man!
-Nick-
Edit: Also, I didnt realize the MIL issue until my first run down the strip.
[Modified by B19CivicHB, 12:33 PM 10/16/2002]
Im new to the Honda scene but not new to cars, how do you run 12.5:1 compression on 94 octane gas?
[Modified by Mighty, 5:55 PM 10/16/2002]
edit: the elevation is 800 feet
[Modified by Archidictus, 4:29 PM 10/16/2002]
not running the **** out of it
.... good one .......... Yeah I remeber snaping my puny LS axles, trying to launch in hard a$$ mode.
your 1/8th mile times aren't that great either. they're pretty consistent w/ the 14.4 actually.
-Nick-
Do yourself a favor and get your car dynoed and tuned. With 12.5:1 compression, try running that race fuel thats 100 octane from 76. Otherwise, good time considering this is your 1st runs. Goodluck.
y did u even bother goin to the track with ur car in that condition, i always thought it be best to work all the bugs out before heading down to the track as to avoid embarresment with a built motor... i pulled a 14.41 with 2.34 60' in a 94 rs integra with b18c1 i/h/e on bad *** tires(as in shitty)
[Modified by lazyguy, 2:38 AM 10/17/2002]
i dont think thats that good i actully think its bad i had a stock b16 with gsr tranny and a chipped p72 and a straight pipe with stock exaust and an intake
15.2 at palmdale and a 14.3 at pomona on street tires
