93 civic not getting spark
my brother's civic is a 93 ex
d16z6. he put a new bottom end from an auto car with his old head in. wired all up and started the car last night. ran fine after a few seconds.
turned off, adjusted timing. started up again fine.
turned on one last tie for the night, and then it died.
now it will spin, but no spark.
checked dizzy from his car on mine, and works fine. mine is a 92 vx.
he has no codes on his p28 ecu.
he has power at the yellow/black wire at the dizzy.
fuel pump primes, the brake light stays on oil and engine light come on then go off.
any ideas?
any ideas?
he said he just checked voltage on the black/yellow and it gets 10.xx voltage, not 12.
he said the yellow and green wire gets continuity, but he did not check the voltage on it.
should he check voltage while he is trying to start it? or just with key to onII position?
he also put a known good ecu in the car and nothing as well.
we tested his distributer on my car and its fine
so distributer and ecu are fine.
no cel
cel goes on then off
gets fuel
timing is good
no cel
gets fuel
timing is good
we just went and tested
black/yellow is 11.8 key on and 10.5 with car turnign over
yellow/green is 0.6 with key OFF and on, and 0.5 when turning over
i will go look at the fuse, acg but in the troubleshooting i didn't see it.
he said he already checked them all
but i will
but i will
Do an end-to-end continuity test from the ICM to the ECU to test for an open.
Do a continuity to body ground test at the ICM side to test for a short.
I did continuity test from the yellow wire with green stripe from the plug into the distributor back to the plug from the engine wiring harness into the other wiring harness which leads into the ecu/interior components. i confirmed that the wire going into the ecu was not the same color if i remember correctly. . i recall it was red witha green stripe (may be wrong) for the most part the wire seems "good". My running theory is that something is preventing the proper voltage to be supplied to give the signal to the ICM in order to trigger the ignition coil. THIS IS THE BROTHER of rountreesj. My question is what exactly could be causing loss of power to the ecu or elsewhere??? I borrowed a friends ECU because i was under the impression that mine MUST be bad. . .i was wrong. didn't do anything.
to clarify. . . i did continuity test with a voltmeter that beeps when there is coninuity through the wire. which IN MY OPINION isn't really hugely reliable however seems to be reliable on other things
are there grounds that i should check for around the ECU? i don't know where they would be exactly. or perhaps any common relays that control the ECU? I noticed an unusal symptom arose for the first time. while trying to start the car (turning it over with the starter) the check engine light would flicker very faintly. . . as if effected by the starter or starter switch of some sort??? something. question being is there some sort of wiring that could be lose up near the key ignition side or otherwise. It almost seemed like the use of the starter was sucking so much electricity that it was preventing the ECU from staying on. ???
I've run across alot of weird things going on before. . . bad horn made my break lights not work and interior lights turn on and off in my old crx. had bad parts in the distributor. I've never run across anything quite this frustrating. So all the help on this is appreciated. Thank you to all who are replying.
Next do the igniter unit input voltage tests at the coil and igniter unit. See FAQs sticky for diagram.
I found a thick gray wire that has been run from a white wire next to a black and red wire. i think i may have found the issue. . . possibly the power wire TO the ECU? which wire is the power wire/wires to the ECU?
I did do a continuity test on the other wires that you mentioned. and did so basically each way about three times. partially completely each part connected every way possible. that ONE yellow and green ALL THE WAY to the ECU is good. HOWEVER as stated. . . there is a gray wire that has continuity that has been added ( looks to be in place of a lost wire) and then connected back to the same white wire (well if the white wire was there) where it is connected it has continuity yet at the end of the ECU plug the white wire no longer has continuity. is it safe to assume that this is most likely the culprit? or are there wires that aren't suppose to carry elctricity at any point to and from the ECU???
correction gray wire is only attached to white BOTH ends. . BUT there is some sort of "jumper wire" going from white/gray wire splice crap thing to the black wire with red stripe
i will try to post pictures. . .but to your knowledge. . .is there any good reason for these wires to be in such a condition as described?? it seems like something someone did and just doesn't work well at all and should be put back to whatever is closest to correct.
