**Go hard. Toda cam gears and Rocket Motorsports M22X cams**
Old Aug 8, 2012 | 02:31 PM
Si Jeff's Avatar
Default **Go hard. Toda cam gears and Rocket Motorsports M22X cams**
I have a set of Toda cam gears for b-series. I am paypal verified and located in Albuquerque, NM. Shipping is available with tracking number to locations in the continuous 48 states. The best way to get in touch is through txt/phone 619 578 1896.
Toda b-series cam gears $200
Rocket M22X camshafts. Sold
Old Aug 8, 2012 | 07:13 PM
Si Jeff's Avatar
Default Re: **Go hard. Toda cam gears and Rocket Motorsports M22X cams**
ttt
Old Aug 8, 2012 | 07:18 PM
Edwin909's Avatar
Can you use these cams with itr valve springs?...
Old Aug 8, 2012 | 07:28 PM
Si Jeff's Avatar
No. Upgraded valvetrain is needed. I wouldn't recommend it
Old Aug 9, 2012 | 12:05 AM
mouab18c1's Avatar
Whats the comp ratio recommended for these?
Old Aug 9, 2012 | 08:02 AM
Si Jeff's Avatar
At minimum 11:1. I had them on my 12.0:1 ITR motor. These cams are the same cams that were used in the Omniman 200whp B16 build.
Old Aug 9, 2012 | 09:42 AM
mouab18c1's Avatar
I'm assuming these are not drop in cams?
Old Aug 9, 2012 | 05:05 PM
Si Jeff's Avatar
If you have upgraded valvetrain and get a tune.
Old Aug 9, 2012 | 08:31 PM
mouab18c1's Avatar
I'm running a Crower valve train. I tune using Neptune. Just not familiar with these cams. Do yo have the lift durations? I'll try googling
Old Aug 9, 2012 | 09:11 PM
Si Jeff's Avatar
Rocket Motorsports M22x
Intake Lift 12mm / Duration 236
Exhaust Lift 12mm / Duration 226
Old Aug 10, 2012 | 07:30 AM
Si Jeff's Avatar
The items are for sale together or separate.
Old Aug 10, 2012 | 10:40 AM
mouab18c1's Avatar
What's the lowest price for the cams shipped to 99207?
Any markings to prove they are m22 cams?
Old Aug 10, 2012 | 11:25 AM
DDTECH's Avatar
They are not, they were used, but could reach the goal.. they ended up using a "type A" cam of some sort to achieve the 200whp mark.. its in the thread here on honda-tech.
They are fine for any stock compression and will give room to grow. Those numbers are also way off.
Old Aug 10, 2012 | 10:27 PM
Si Jeff's Avatar
pm's replied
Thank you for the clarification. What numbers are way off? If you can provide the correct numbers it would be greatly appreciated. Thanks in advance.
Old Aug 11, 2012 | 12:28 AM
Midnight EG6's Avatar
whats holding the gear in your photo? i don't see any fingers or anything underneath holding up. looks weird. lol
Old Aug 11, 2012 | 10:14 AM
Si Jeff's Avatar
lol my hand is underneath and the gear is secured on the cams
Old Aug 11, 2012 | 04:02 PM
Si Jeff's Avatar
up
Old Aug 11, 2012 | 06:55 PM
Si Jeff's Avatar
ttt
Old Aug 12, 2012 | 02:20 PM
Si Jeff's Avatar
Up
Old Aug 12, 2012 | 04:01 PM
shocker911's Avatar
how much power did you make with the cams? im very interested in them
Old Aug 12, 2012 | 11:55 PM
bond123's Avatar
you still have Toda b-series cam gears?
Old Aug 13, 2012 | 02:00 PM
Si Jeff's Avatar
Cams are pending
Yes. I can't reply to your pm because your box is full? Send txt
Old Aug 13, 2012 | 02:07 PM
shocker911's Avatar
sent payment on cams just now
Old Aug 13, 2012 | 02:10 PM
Si Jeff's Avatar
Cams sold
Old Aug 13, 2012 | 09:46 PM
Si Jeff's Avatar
TODA
