Toda cam gear center bolt
Anyone know what bolt to use with these gears? Can you use the oem center bolt? Or do you have to use the toda supplied bolt. I bought them used from here and they didn't come with the bolts. =/
this one
See how these have the bolts?
"TECHNICAL NOTE
Some aftermarket campulleys use connecting bolts that are not compatible with TODA camshafts. The use of these bolts could damage the TODA camshafts. If you plan to use TODA camshafts, we only recommend using TODA campulleys to prevent damage to the camshafts."
this one
"TECHNICAL NOTE
