Main Relay or Fuel Pump?
Old Aug 8, 2012 | 10:35 AM
UniqueX707's Avatar
Icon2 Main Relay or Fuel Pump?
So yesterday my car dies on the freeway. I pull over trying to start sounded liek it need gas i put gas nothing.. When i turned it on it would start then just choke! Then try an listen for the fuel pump to go on for a couple of sec. And nothing no sounds from the fule pump. I grab the Main relay and i just feel a click? What can be the problem. I'm thinking the main relay need to be resolder? I check the fuse under the hood none are blown.
1992 Honda Civic LX 5 Speed
Old Aug 8, 2012 | 10:48 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Main Relay or Fuel Pump?
Remove the top small bolt off the fuel filter and turn to accessory power, does fuel stream out?
Old Aug 8, 2012 | 11:20 AM
Former User's Avatar
Yes
Old Aug 8, 2012 | 11:36 AM
UniqueX707's Avatar
Originally Posted by RonJ@HT
Yes
If that doesnt fix the problem what else can it be!?
And yes I took the blot out and it does shoot gas out
Old Aug 8, 2012 | 12:21 PM
Resolder and go from there.
karrar55
Mar 20, 2011 03:13 PM
916MINI
11
Aug 11, 2008 09:51 AM
1hotintegra
Aug 13, 2004 02:12 PM
RenoRacing
Sep 8, 2002 09:41 PM
