CC Twin disc problem or trans issue?
I have a H-series tranny with a CC twin disc setup. When everything is cold the trans has no problem going thu the gears. After driving a little bit when at a stop when I go to put it into 1st gear it always grinds. I have syncro tech syncros in the trans as well and just had it rebuilt no less than 500 miles ago. Do you think my 1st gear is taking a crap or is it a clutch issue?
I have already replaced a set of carbon syncros because of that clutch. At least I am thinking it was the clutch. I had the pedal adjusted wrong and it toasted them. I put more play in the pedal since my last tranny build and the same ish is happening. Any other options that you know of that we can go with for a clutch? You would think for the money paid to CC that they would give you a product that preforms properly.
I wonder if Competition Clutch will chime in. This clutch has been nothing but a nightmare from day one. This is my first twin disc and on the instructions they say the clutch's are labeled make sure you put the one that says "tranny side" on the tranny side. I did that. After getting the whole thing put back together I couldn't engage into a single gear. Long story short comp clutch put the stickers on the wrong discs. Good thing I didn't pay a shop to do the work otherwise I prolly would of been eff'd. Comp clutch said "sorry" and sent me a t-shirt.
Lol at least you got a shirt. I will show you my disks they tampered with and said it was my fault. You can see the vise grip marks where they bent them. There is a thread floating around here that i made a while back. With the pictures and emails. I still have them and will keep them forever just to show people in person that I'm not joking.
Do you have a clutch stop installed? Repeated over extending of the diaphragm can lead to ultimate failure.
Do you have time and are you willing to sent the clutch in for inspection? Although the twin disc assemblies do not carry a warranty I have been able to help out our users by updating their assemblies and no or very little cost. (such as MR.johnson where I was able to update the diaphragm assembly to new parts at no cost to him regardless of the other issues he was having with his system.)
Dominic
tech@competitionclutch.com
Have you verified that the release system has enough travel to properly disengage the clutch? You can check this at the clutch fork with a buddy pressing on the clutch pedal.
Dominic
Dominic
Dominic, when a part fails and its my fault I take full responsibility but its not this time, other companies we have worked with go out of the way to help. But this has been a nightmare from start, i hate to bash on cc everytime a thread comes up but its bullshit. Send my money back, you can have this "rebuilt'' clutch back and cc will never hear from me again.
Dominic
Dominic
Only issue I see is this method won't get the problem solved. Nothing is wrong with asking questions, but there are several variables here.
Manufacturer issue and install issue. Hope you get it resolved soon because there are a lot of people who have never had issues with cc including myself. Best of luck to both of you
Ahobbs, did you see the pictures? Please tell me how that's from hanging the trans on the clutch... Bending one corner of one puck on each disk? No.
I'm on my phone I can't see exactly what you are saying. By I don't understand why they would do that to Thier own clutch. It makes no sense whatsoever.
my clutch had the wrong parts to begin with, they said it was send with parts for the old style top hats and needed to be changed , it never worked right, the disks i needed to buy to "fix" the problem were 100% different and look like a much thicker plate, more pad area and beefy hubs. a clutch with 2000 miles and under 4 passes at the track should not **** out... i wish dominic would chime in to explain how a single puck gets twisted by hanging a trans off the disk, the hub would be bent in the disk not just a single puck twisted...
We are having similar issues with our brand new cc twin. I chalked it upto not having the pedal stop and/or free play properly adjusted.
We just got the clutch in it last night so ill try to get some more time with it.
i had the same problem jamie, i can send you pics of my syncro when my twin was junk. its from the clutch not releasing all the way. go into 2nd, then first and im willing to bet it will go in fine. this is bryan btw. comp is one of the worst things i have bought for my car.
The Clutch didnt break that transmission dude. And second is KNOWN to be weak in the H trannys... Usually the M2F4,B4, or A4 moreso than the y4, the ratios and tooth count is different... M2Y4s I always broke 4th (And a couple seconds, but ALWAYS fourth).
By the way now that i Look, thats third gear thats broke... IS it an H23 trans by chance(M2S4)?
Any TQ above 375ish thats hooking well s going to seriously strees the set. COmpounded by weight (Which is what makes my car more problematic, its heavy and makes WAY more TQ than that) I started breaking **** regularly at around 375-380 TQ... WHich was my pump gas tune, so it happened alll the time before the gearset. Even with the Tilton FCV. It helped the Hit on the gear off the shift, but RAW POWER is what breaking the teeth. NOT the clutch itself. A FCV MAY help though. I have one.
To make an educated judgement I need to see the sleeves, and the inner linings of the syncros, and super close up od the outer edges of the blocking rings.
That number 3 looks like its just seen its limit of hits on it . Ive ONLY broke 3rd in H23 trannys
Stock gears wont last long at the track, especially if youre hooking andf getting out. Ask me how I know ;O)
Ready for a gearset yet?
Ive had issues with my comp clutch (Specifically disk splines) but never anything but that, but... This set of disks in it right now is working great. If you know anyone looking for a clutch, mines for sale for 700. I got a new deal coming :O) Complete.
PM if you know anyone looking for a Complete twin with TO bearing and everything.
