Cel p1166 and 1167 (i've done everything?)
Throwing both codes on a 02 civic si
Checked wiring
checked fuses (underhood 30's and 40's and underdash. #6 and another i forget)
replaced primary o2 with denso oe replacement from k series parts.com
tried to clear cel with removing negative terminal from the battery and taking out the #12 fuse.
Cel comes back about 1 minute after i turn the car back on.
Do i need to take it to a dealer?
Checked wiring
check your wiring again both at the o2 sensor side as well as the engine harness side. i am willing to bet that it's a corroded or snipped wire somewhere.
i had these codes recently, luckily a new primary o2 solved my code (so far) but i was prepared for all circumstances.
llred_devil2001ll
Jun 4, 2007 12:48 PM
totalimmortal
Jul 21, 2006 02:24 PM
Ricey McRicerton
May 22, 2003 12:38 PM
