Suggestions for middle muffler?
Old Aug 8, 2012 | 01:52 AM
tianporn's Avatar
Default Suggestions for middle muffler?
Hi there,
Can I have some suggestions?
I'm looking to build a new custom exhaust system for my EK Civic. I want to run a middle muffler (in the place where the cat goes). I don't want to use a 'hotdog' style resonator. Instead I want to run something a bit bigger to muffle the sound. This will then flow through to a hotdog muffler in the middle of the chassis and then I will run a straight pipe at the rear (similar to Buddyclub Spec II).
Basically I want the Buddyclub Spec II look but without the noise. That's why I thought having a good middle muffler would work.
Can someone suggest a good middle muffler I can use? Preferably the middle muffler is flat as possible (similar height to the cat) to retain as much exhaust to ground clearance as possible. Any suggestions?
Thanks
titi_vtec
Oct 22, 2011 07:44 AM
RACEPAK
Jan 3, 2010 02:42 PM
Stefan_VTi
May 20, 2003 02:19 PM
VTECTIME
Jan 15, 2003 04:20 PM
Interspy24
Oct 8, 2002 05:54 AM
