Ac compressor clutch rapid repeating engagement solved -- but still not blowing cold
I am not a AC tech. I have read thread after thread and gained some knowledge from it but I am stumped.
- I installed new compressor, dryer and expansion valve. Along with all new o rings
- Held vacuum for 15 minutes
- Charged with 21 oz of freon....
I had to install a after market slim fan onto the condenser and I haven't wired it to kick on yet, will be doing this tomorrow with a hopefully working ac system to follow.
What happens is the compressor clutch is kicking on and off really quickly. Within a second or two.
Would the fan not being on make the compressor do that ?
Its on a 1992 SI with the oem drive train.
Same problem checked what wiring I could see and didn't see any bare wire . Also the fan is pulling the air through the condensor not pushing it out.
I did install the fan and it isn't blowing any where near cold and the compressor is still kicking on and off fast
It says 21 oz of freon on the stamp in the engine bay. That's what I had put in it. Does that sound like too much ?
Before the slim fan was connected though it takes about 1 minute and a half for the compressor to start making it engage over and over quickly. Where after the slim fan the compressor will kick on and stay on for a minute then start kicking on and off again.
And no was done when I got the car 3years ago and the Ac didn't work then either. Would always blow semi cold on the highway then the idle would fluctuate and it would blow hot. Now its doing similar but the compressor can be vividly heard kicking on and off.
Blows colder than ever, or just semi-cold?
R134a compressor?
Do the tests in the diagrams.
