to stop short you gotta stand on the breaks
my gf's 93 accord ex 4dr has bad brakes. you really notice it when you have to stop short. you gotta really stand on the pedal. she said she had the master cylinder replaced a year or so ago. two mechanics told her she needed new front rotors. i just replaced those last night. didn't seem to make much of a difference. plenty of pad left. is it the booster maybe? is there a way to test a break booster?
is there a one way valve from the booster to intake? usually Honda ones are integraded INSIDE that hose. Take it off and flip the ends around.
bleed brake system. if you're having to apply that much force there's probably air in the lines that's being compressed by stomping on the brakes instead of compressing the friction material
if still crappy then check caliper pistons, there should be no fluid leaking from caliper onto pads or shoes.
if still crappy then check master cylinder.
my girl has got the car right now but there is a hose that goes from booster to like a coupler then to intake. i'll look closer when she gets back. maybe that coupler is the valve?
alright, the only way i know is a tube in a jar going around to each caliper (furthest first) while someone pumps the pedal. or is there something i should be doing at the master cyl?
Disconnect brake lines at MC, use soft plastic tubing to route MC fitting back into MC resevoir and pump pedal until air is no longer present. Reconnect brake lines then proceed with bleeding the rest of the system.
skinney6 the easiest way to check if the brake booster works is by depressing the pedal several times with the engine off to bleed any assist.
With your foot on the brake pedal, turn the engine on. Does the brake pedal drop ~1" when the engine starts?
Is the pedal hard and short? Or long and soft? Does it change at all if the engine is on or off?
Rebuild
-Raysbestos
Replace
-Honda
-Fenco
-Many others.
It seems like there is no booster assist, yet you still get the pedal drop at start up. I wonder if the vacuum hose, check valve or booster has a leak that bleeds off or does not allow a continuous vacuum feed ending with your lack of boost assist.
skinney6 Remove the hose to the booster and inspect it for cracks. Cap off the hose and go for a drive around the block. Does the pedal feel the same short and hard? If so there is something most likely wrong with the brake booster system.
thanks all, i'm going to test with vac hose unplugged from booster
i'm looking at master cylinders on rockauto and there are many options
i believe this is a 93 ex, 4 wheel disc with at least front abs
she said the m/c was replaced a while back. given some of the other shoddy repairs i've seen on this car i wonder if they didn't use the correct m/c?
06civic_lx
Jan 4, 2007 12:14 PM
