92 civic power steering help
Old Aug 7, 2012 | 07:24 PM
jdm 1080p's Avatar
Default 92 civic power steering help
so... i wanna put my LS engine from one civic to another and this civic has power steering. I would love to keep it because its my daily. so my reason for this posting is can i use the single cam power steering pump and bracket on the LS motor or do i have to get the LS bracket for the pump or just use a Integra power steering pump and bracket.. Also does anyone know if the power steering tubes are the same. like where it connects from the rack to the pump?
thanks all help is needed
Old Aug 8, 2012 | 01:20 PM
Magik8252's Avatar
Default Re: 92 civic power steering help
I did a B16 Swap into 95 Civic Si. I ended up using the power steering pump and bracket that came with the B series engine. The only thing I ran into was when I hooked up the line that goes from the power steering reservoir to the power steering pump I had to use a light coat of HondaBond.
Reason for this was that the power steering line had the flange that was held in by 1 bolt. The b-series power steering pump was set up for 2 bolts. When I first initially installed everything I had a small leak. More like a tiny drip. After Hondabond was added, I have been good to go no issues or leaks or drips. Works like a champ.
Just my 2 cents. Hope that info helps you out.
Old Aug 9, 2012 | 09:34 AM
jdm 1080p's Avatar
sweet cuz my ls doesnt have the bracket lol... but im sure the junk yard would. otherwise ill just have ot make that work somehow!
Old Sep 13, 2012 | 07:06 PM
x95civicb16's Avatar
so what year was the b16 from? Just curious if that year pump and bracket will work on my 95 civic b16 swap.
Old Sep 13, 2012 | 07:32 PM
evilclown312's Avatar
I have a LS powersteering pump and bracket if anyone needs it!
khailon
May 7, 2011 10:49 AM
Nippo
Jan 20, 2008 07:51 AM
Bioinfomatic
Feb 25, 2007 02:41 PM
not7fifteen
Apr 30, 2002 10:26 AM
