Excess carbon build up and miss in one cylinder
Old Aug 7, 2012 | 02:40 PM
DCRB's Avatar
Default Excess carbon build up and miss in one cylinder
Working on my 92lx coupe 5spd, bought it with a miss fire. did the usual, tune up, swap injectors, still acted the same. so i pulled the head off thinking i had a burnt valve (even though the head has recently been rebuilt from a snapped timing belt per the previous owner) and noticed some odd things in my block, cylinder 4 has some odd scoring, and the honing cross hatch is far more visible than in cylinders 1-3, which are pretty smooth. car has 236k miles on it... i also noticed the head has two different kinds of exhaust valves?
here's some pix, i'm disassembling this little by little each day.
head:
cylinder 4:
other cylinders:
Old Aug 7, 2012 | 07:07 PM
DCRB's Avatar
Default Re: Excess carbon build up and miss in one cylinder
I should add i have not cleaned the egr ports yet as i bought a f22a6 intake manifold, cam, and ecu from the jy and was going to clean that up and install it. If it turns out my block is bad or my head atleast um just going to get an f22b1 and swap it
Old Aug 7, 2012 | 09:32 PM
doctorbee's Avatar
did you test compression? get the right valves.
Old Aug 7, 2012 | 09:55 PM
holmesnmanny's Avatar
Ya, I woulda compression tested it before pulling the head. You could get a set of precision straight edges and check for warpage. That cylinder is prolly dead.
Old Aug 7, 2012 | 10:27 PM
DCRB's Avatar
Yes i did actually i got an average of 125psi in 1-3 and 115 in cylinder 4. Car was as warm as i could make it wout driving it before i stopped breathing due to the exhaust being so stinky. Drove fine home minus the miss at idle just has bad tags
Old Aug 8, 2012 | 10:25 AM
DCRB's Avatar
any one have any idea why the physical condition of cylinder 4 looks different?
and honestly, should i source another head?
Old Mar 23, 2016 | 04:56 PM
DarknightDay's Avatar
sounds like your piston rings is about to go look for smoke. at first i thought my valve seals was gone cause of misfire and oil in exhaust port but i replaced and i had the same problem so that left the piston rings. tore it done and all 4 walls were scared but 3 n 4 the most.
Old Mar 23, 2016 | 05:03 PM
It's likely the piston rings are bad if you are sure the compression test is good.
115 psi isn't something to be highly esteemed. I would swap out the engine for a jdm f22a
Old Mar 26, 2016 | 01:37 AM
CiGHonda's Avatar
I have the same problem, #4 cylinder is running richer than the other 3. Over time it looks like that took a toll on the cylinder walls.
I'm thinking of having my injectors flow checked.
ajth87
Jul 21, 2006 01:27 PM
97TegraLS
Sep 16, 2004 05:19 PM
polakking
Jul 14, 2004 04:01 PM
James
Jan 13, 2003 07:04 PM
jdstoledo
Apr 6, 2002 03:54 PM
