Rough idle at cold start
1999 Civic LX with a D16Z6 1.6L vtec
When I first start it up, it will be around 1100-1400 rpm for a minute and drop to rough idle about 500 rpm if not less, I press the gas and get it about 2500 rpm (trying hard not to press real hard)
After a minute or so after that, if I turn off the engine and turn it over again it will be fine.
I'm thinking it's the idle air control or a vacuum leak. There is a sound that sounds like a vacuum leak near the cold air intake pipe.
Any advice would be appreciated. I'm new to Honda's.
If you can hear what sounds like a vacuum leak...that is probably the awnser to your idle issue. Never hurts to clean the iacv w/ some brake cleaner anyhow. They like to fill up w/ carbon. I do mine every month or 2 as my high(er) compression motor produces more carbon.
It gets worse than this, but this is what it does (when the RPMs drop too where it's going to stall)
https://www.youtube.com/watch?v=WzPvmE7Ppe8
Apple395
Aug 16, 2013 10:13 PM
