96 2.2 surging (iacv)
is there any way to block this part? i have been through 4 of them in the past 3 months and im tired of forking out 200 for a iacv. can the 2 coolant lines plumbed straight bypassing the valve and leave it plugged in or will it still surge? its bouncing from 3500 to 900 rpm please help no waranty
iacv probably isn't the root cause then. something else may be causing your surging problems. have you checked for vacuum leaks? when replacing the IACV did you replace the gasket? any check engine lights?
ok to my understanding the 2 1/4od hoses are coolant correct? they wouldnt have anything to do with a vacuum leak. is there a diagram out here on the net for the routing of the vacuum hoses? the car is surging from 900 to 3k and when it drops there is a release of air ( kinda like a blow off valve) but its a stock motor ,when ever it runs right at 900-1k you dont here any sucking common to a vacuum leak but yes i will look around and clean the iacv thanks nuss and doc
DriveSlowHomie
Dec 17, 2005 06:02 AM
