850wph BEAST! PARTOUT!!!!
**UPDATED** 1/4/13
Sad day for sure but I just took a new job and moved to a place where I can't really race the car anymore, don't want to let amazing parts sit and collect dust. Do me a favor and give some of this stuff a good home.
Absolutely no corners were cut with this build, only the best new parts have ever been purchased. Setup ran 9.7 @ 157 at 5300 ft elevation in Utah this last year.
I am pricing everything to sell and will not entertain: "whats your best price man" requests.
Here is the parts list:
Full Race T4 twin scroll top mount-$750 plus shipping (new years special)
Custom Edlebrock Victor-X IM w/8 injector ports, runners ported as well (will include matched hondata gasket)-$350
T1 Style Crank case pressure case with -10an lines-$350
Dual Bosch 044 X 2 (practically brand new, three passes no dyno time) $175 each
Tial 44mm MVR waste gate -$275
3" EK Charge piping W/ Tial Blowoff.
Hondata 4bar map
Ksport 36 way adjustable full coilover suspension-$650
Custom B18 ATI Super Damper $sold
Shell: 98-99/00 converted EK W/10pt Chromoly cage (IHRA/NHRA Legal)
As is rolling chasis: W/buddy club wheels, Ksport suspension Kirkey Seat, Si Cluster, and Removable steering wheel, and sumped gas tank w/ -8 lines run- $5,000
Price can be adjusted down depending on what you'd like it to come with.
BELOW ARE SOLD ITEMS JUST FOR REFERENCE OF WHAT CAME WITH THE CAR.
Golden Eagle Sleeved 84mm Block, T1 Spec JE pistons w/ oversized wrist pins, Manley rods, 625 rod bolts, Morroso 5qt pan-SOLD!
4Piston CNC GSR Head, flows over 300 CFM!! Ferrea oversized valves, magnesium bronze valve guides-SOLD!
Massive T1 Custom Ferrea Cams/rocker assembly (one of only four sets made)-$SOLD
Golden Eagle cam gears, from T1 cam trigger kit (magnet installed)-Sold
Jojo style Strada front end-$SOLD
Trans-SOLD
Surge tank sold but 044's are still up
160 amp alternator-$SOLD
Injector Dynamic 1000cc injectors SOLD!!
Golden Eagle Pro fuel rail - SOLD!
Brand new still in box Hondata CPR coil pack retrofit setup, comes with CNC distributor block off plate and CNC coil mounting plate. Most recent purchase, never got a chance to install it. -SOLD!!
Spal 2000 cfm radiator fan $Sold
Hondata S300 with data logging, launch control...all the goods -SOLD!
Full Race traction bar-$Sold
Drive Shaft Shop 5.9 Axles with knuckle assembly, brakes and cross drilled/slotted rotors-$Sold
Custom Exospeed 13x10 5'' backspace Star 8's with brand new MT 24.5x9-13 (tires alone were $200 each) -$SOLD!!
1200hp 4" thick Garrett core intercooler! Easily my favorite piece on the car. Turbo side is backdoor - $SOLD
Hondata 4bar map
Trans-SOLD
