Honda S2000 Honda S2000
Shifter moving too much
Old Aug 6, 2012 | 06:34 PM
Mark671671's Avatar
Default Shifter moving too much
Anyone know the DIY mount for Shifter bushings? Or is this the reason why it moves too much.. Even when I press on the gas it seems like it moves too much.. Anyone know why it does this?
Old Aug 10, 2012 | 09:27 AM
Blacksole's Avatar
Default Re: Shifter moving too much
Hi there are no "shifter bushings" as such. Does shift stick feel loose or floppy? If no then look at the engine mounts. The rubber can seperate fron the steel causeing the engine to try to roll over. when you jack up car to inspect the mount USE JACK STANDS. Good luck!
Bill
Old Aug 10, 2012 | 09:36 AM
Boots's Avatar
its probably motor mounts or tranny mounts...like stated before, there are no "shifter bushings"
Old Aug 13, 2012 | 04:59 PM
postman's Avatar
a lot of times the shifter needs cleaned and lubed at the lower ball piece. if you do this use a quality grease such as honda hi temp urea.
Old Aug 20, 2012 | 04:41 PM
TryinaLearn's Avatar
This happened with my civic and for me the problem was the motor mounts. It was pretty obvious because when I changed pace (speeding up or slowing down) I could feel the motor lurch a little & I would feel the stick jiggle a little.
Old Aug 23, 2012 | 03:34 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
How much movement? The shifter is attached to the trans directly. So it's going to move as much as the drivetrain does.
Old Sep 14, 2012 | 06:39 AM
92cxhatch169's Avatar
i had this problem when i first bought my car. upon inspection i found that all three mounts were broken in half. i replaced them with some innovative mounts and problem solved.
Old Oct 26, 2012 | 08:18 AM
CHONCH2's Avatar
another thing that can cause a little too much shifter movement is the axle cups being worn. if you notice a vibration from the car at highway speeds coming from the rear, that is the problem. you can take the axles apart and swap the cups and the problem will be solved. just did it to mine.
Old Oct 26, 2012 | 08:26 PM
Black S2K's Avatar
ur car is going to blow up
Dm914
Apr 20, 2017 06:55 AM
Ryan96GSR
Mar 12, 2012 02:26 PM
SoullessJapaneseMachine
14
Apr 11, 2010 11:21 PM
zenon8890
May 1, 2006 01:08 PM
AzntstyleZ
Feb 9, 2004 11:33 AM
