Transmission & Drivetrain Gearboxes, Differentials, Clutches
Which Tranny Is Best for B16A, GSR OR LS
Old Aug 6, 2012 | 03:32 PM
Aaron Cayabyab's Avatar
Default Which Tranny Is Best for B16A, GSR OR LS
Two things i would be doing,
Race the local Cars Here
And Daily Driving
Which of these trannys would be best without wasting a lot of gas?
Old Aug 6, 2012 | 04:31 PM
exotik4doorcivic's Avatar
Default Re: Which Tranny Is Best for B16A, GSR OR LS
gsr, but id rather get a b16 tranny
Old Aug 6, 2012 | 04:51 PM
brandonEM1's Avatar
If the B16 is stock with just bolt ons, get a B16 trans....
Old Aug 6, 2012 | 04:53 PM
Caddiman's Avatar
maybe stupid answer here but wouldnt a type R tranny be best??
Old Aug 6, 2012 | 07:16 PM
Thanks for all your answers, specially the ones that didn't argue
It's my first B series swap so I don't know much,if anyone has done a b series into a ek can you guys help me out I have some questions I dot understand and I don't wanna keep posting so pls PM and we can text to make things easier thanks!
Old Aug 7, 2012 | 07:40 AM
kyden's Avatar
b16 or type r (usdm r has the same gear ratios as the b16)
Old Aug 8, 2012 | 06:03 AM
MMMGIRL's Avatar
GSR is going to have better ratios for racing, while LS is going to save you gas on your commute. They weigh themselves out you just have to pick which is more important to you.
Old Aug 8, 2012 | 12:02 PM
brandonEM1's Avatar
Actually you use more fuel in a B16 with a LS trans.
Old Sep 4, 2012 | 11:22 PM
Roger_<3_Honduh's Avatar
ls tranny has longer gear ratios and the gsr would be good you would use less fuel but you would notice a big difference in the final drive of the gsr
Old Sep 5, 2012 | 12:10 PM
parts@synchrotech's Avatar
I would go B16 with LS 5th gear set to help keep RPMs down at highway speeds since you are concerned with fuel economy.
Or if you can swing it...Type R since it comes with a factory Limited Slip Differential and add the LS 5th gear set.
Old Sep 5, 2012 | 03:10 PM
Runnerdown's Avatar
On a b16a you need all the gearing help you can get. B16a/R gears ftw.
Old Sep 12, 2012 | 09:57 PM
ek2knick's Avatar
anyone selling a ls tranny. pm .. i drive about 80miles a day on the highway and b16 tranny is killing me in gas.. i need this ls tranny asap
Old Sep 13, 2012 | 01:52 AM
Aquafina's Avatar
You'll get better economy with a B16 trans than you will a GSR, LS, or B16 with LS 5th.
For the average driver with current gas prices it will take a couple of years for a trans swap or 5th gear swap to pay for itself in fuel savings.
Just an FYI.
Old Sep 14, 2012 | 11:03 PM
dirty19's Avatar
Ridin Dirty in Cali
Please explain this theory in depth.
Old Sep 15, 2012 | 09:21 AM
Aquafina's Avatar
Higher RPM = less throttle needed to keep it moving. Less throttle = less fuel used.
SikofFalln
Jun 1, 2008 12:42 AM
Jmunk
10
Jan 20, 2005 04:37 AM
boosted k20
Oct 30, 2004 06:31 PM
SilverDc2
Sep 20, 2003 11:33 PM
