trying to set the valve lash
Old Aug 6, 2012 | 12:59 PM
jordy478's Avatar
Default trying to set the valve lash
im trying to set the valve lash on my 94 accord...the only problem i seem to be running in to is that the part were you put the flat head screwdriver at to adjust it seems to be stuck...is there any tips to getting that broke loose so i can adjust the valve?
Old Aug 6, 2012 | 01:06 PM
beatontheeznutz's Avatar
Default Re: trying to set the valve lash
did you break the nut loose first? once you break it loose then adjust it with the flat head.
GhostAccord's Avatar
You need to use a 10mm closed end wrench to break the nut that will allow the adjusting screw to be easily adjusted.
Old Aug 6, 2012 | 01:15 PM
just break it loose with a 10mm deep socket. it shouldn't be hard.
Old Aug 6, 2012 | 01:33 PM
You will also have to use a 10mm wrench, otherwise you will not be able to adjust the screw and tighten the nut back up while keeping the adjustment screw from moving.
Even better would be to use a valve adjustment tool. aka a 10mm jam nut adjustment tool. Pretty easy to use vs having to use a wrench and screwdriver separately.
Old Aug 6, 2012 | 02:28 PM
jordy478's Avatar
no i mean ive broken the bolt loose...but the part you adjust wont turn
Old Aug 6, 2012 | 02:35 PM
Is your engine at TDC for that cylinder? The rocker should have some movement to it.
Old Aug 6, 2012 | 02:43 PM
jordy478's Avatar
yea its at tdc i think imma go buy that tool and see if it will work better
Old Aug 6, 2012 | 04:11 PM
jordy478's Avatar
were would i buy that tool from? none of the local stores carry it. neither does harbor freight
Old Aug 6, 2012 | 09:16 PM
you'd have to order it online. Amazon or eBay. Got mines for under $10.
Old Aug 7, 2012 | 05:28 AM
jordy478's Avatar
yea was hoping i wouldnt have to i need it like today lol
Old Aug 7, 2012 | 08:01 PM
Hidenplanvew's Avatar
Find a Snapon guy, Mac, maco they all have them.. Go on there sights and find a rep in your area
Old Aug 7, 2012 | 08:47 PM
nus_dogg's Avatar
All I had is just a 10mm socket & ratchet to break the nuts loose, 10mm wrench to hold the nut when I turn the screw, flat head to turn the screw, and a propane torch to heat up the stuck screws.
I just did valve lash on my bro's new F22B1 I put in, and those turning screws are stuck to the nut even if the nuts are loosened. What I did was used a propane torch and torch the nut and screw for a good 15-20 sec then turn the screw. It works flawless! All of them were stuck like that, so I had to heat them up to break them loose.
Benefitx
Sep 6, 2014 06:20 AM
kornerk12
Nov 28, 2008 10:37 AM
gsr-2nr
Oct 27, 2003 03:00 PM
Andrew 825SM
Jun 19, 2003 02:09 PM
Jamison
Mar 16, 2002 02:17 PM
