H22A4 into 96 Odyssey
Whats up HT,
So, i've been fooling around to find this information that I need, I want to do a H22A4 swap into my 96 Odyssey and stays automatic.
I found some great info about doing this swap, because basically my 96 odyssey is the same chassis as 94-97 accord, and I know that I need mix and match the engine mount, and I'm able to use my F22B6 Auto tranny as well.
But now I got only 1 thing that stuck before doing this swap, which ECU that I need to use to make it run properly since H22A4 ECU from 97-01 prelude got Immobilizer built into it, so what I'm wondering is which ECU that I can run with this set up?
Note: this swap is going into 96 odyssey and stays automatic, since my wife will be using the van most of the time with the kids, and I am mechanically and electronically inclined and I have no problem doing all of this.
Thanks in advance.
Thanks in advance.
trequartista_10
Nov 17, 2012 10:26 PM
