GSR Very Low idle want to die
Hi,
Been having some trouble with my b18c1 motor in my Del Sol. It's a 95 GSR motor. It has been having a really low idle and it dies sometimes when I put it in neutral. The car idles at about 500-600 when its warmed up. When I start it up cold I need to give it gas for a little bit to keep the rpms up. I''l start it, it will turn over just fine but then the rpms will go down to below the 500 mark and die. If I give it a little bit of gas I can normally keep it idling at 500 in the mornings.
I replace the plugs/wires/cap and rotor almost a year ago. Just changed the Fuel filter and cleaned up and tightened all the grounds. The exhaust is not clogged.
Any ideas on what I should try next?
Read this....
http://www.superhonda.com/forum/f55/...oblems-259965/
I did everything also and turned out my lumpy idle was from valves needing to be adjusted...
