T1 cam trigger, AEM, COP?
Old Aug 5, 2012 | 07:35 PM
DraginX's Avatar
Default T1 cam trigger, AEM, COP?
Ok guys, I've been searching and reading all day and can't seem to come up with an answer to this specific question.
Is it possible to run a COP setup with RSX coils, a T1 cam trigger kit, and an AEM 10-1050 box, with no amplifier, and the stock distributor completely removed?
From what I understand the RSX coils are a 3 wire coil setup with a built in amplifier already so it doesn't need another external amplifier. Is this correct?
Old Aug 5, 2012 | 11:59 PM
Mike Lowwryyy's Avatar
Default Re: T1 cam trigger, AEM, COP?
Do you already have those parts? Thats a hella expensive and complicated route for ignition in my opinion...
Old Aug 6, 2012 | 03:50 AM
DraginX's Avatar
I already have the AEM and the cam trigger kit on my car. Just looking for ways to get rid of the distributor. And a set of RSX coils are easy to come by and not that expensive.
Old Aug 6, 2012 | 04:27 AM
Is this a turbo car? Its a good question you are asking as Im not really sure myself. If you are looking to get rid of the distributor because of the ignitor... you could run an ignitor bypass circuit and a mallory box... Thats what I have and I think its a cost effective ignition system
Old Aug 6, 2012 | 04:30 AM
DraginX's Avatar
Sorry didn't put that info, yes this is a turbo b-series.
Old Aug 6, 2012 | 04:32 AM
E Town DSM's Avatar
yes it is possible with the small aem boxes
Old Aug 6, 2012 | 04:44 AM
DraginX's Avatar
What do you mean by small aem boxes. I have the newer style v1 box with the jumpers inside.
Old Aug 6, 2012 | 05:27 AM
ralph11sec's Avatar
you dont want to use M&W or AEM twin fire?
i thought only series 2 ems have the coil drivers that you can wire a smart coil directly
Old Aug 6, 2012 | 05:36 AM
DraginX's Avatar
Thats partially what I want to know. Do I need the M&W or twin fire or does this aem 10-1050 box have the proper setup to be able to do it with the coils with built in amplifiers?
From the searching I have been doing it looks as if it is possible but I haven't found anyone who has done it this way.
Old Aug 6, 2012 | 05:38 AM
DraginX's Avatar
I know some of the original boxes only had 3 ignition channels but I'm pretty sure the newer boxes have 4.
Old Aug 6, 2012 | 08:14 AM
DraginX's Avatar
Ok so my box does have 4 ignition channels just checked with AEM. So has anyone tried these coils with the epm? If so how did you wire them?
Old Aug 6, 2012 | 08:22 PM
E Town DSM's Avatar
the k coils have built in igniters so no need for a twin fire or m&w. If you were running a cbr or pencil coil then you would need the twin fire or m&w as they act as the igniter. What i recomment is the t1 trigger and the k coils if you dont wanna spend the extra money on a m&w. Highly recommend staying away from the epm or even twin fire seen them do way to much goofy stuff which isnt worth risking a motor over.
Old Aug 7, 2012 | 02:38 AM
DraginX's Avatar
Thanks for the help. I finally found a good rsx coil circuit diagram so I have them some what figured out as to how to wire them. I'll let you guys know how it works and possibly do a write up on it so it's here for anyone else looking.
Old Aug 7, 2012 | 04:29 AM
E Town DSM's Avatar
STRDonline.com offers a harness for that setup if its not on there page email them they do nice work
Old Aug 8, 2012 | 10:25 PM
Julio@Bisimoto's Avatar
Rywire sells a sub harness specifically for K-series coils Click on this link: Rywire k-coils wire sub harness
Old Sep 25, 2012 | 05:11 PM
DraginX's Avatar
Ok so I have this setup put together but having a problem I was wondering before hand if it would arise. When I crank over the engine while watching aempro I see that the injectors are not firing at all.
First I tried setting up the aem using the method outlined on the aem site http://forum.aempower.com/forum/inde...c,23519.0.html
I set my cam/crank sensor in the wizard as an epm. Tried it and no injector pulse.
Then I tried it with the original t1 cam trigger setup for the cam/crank wizards, etc and still the same thing.
Now that the distrubitor is gone is there something missing that I should be setting up to tell the injectors when to fire?? I'm assuming there must be a way I can set this up off the cam trigger? Any and all help is very much appreciated.
Old Sep 26, 2012 | 12:10 PM
accorse07's Avatar
Those instructions state to turn off your injectors and sync the ignition. Did you sync the ignition? If you did and you followed the instructions....Did you turn your injectors back on?
Old Sep 26, 2012 | 12:25 PM
DraginX's Avatar
Yes, and yes, I got it all figured out, called AEM and come to find out there were some other jumpers that had to be moved for this application where their application they have on their site didn't need to be moved. I am going to do a write up on it for anyone looking to do this in the future.
Old Oct 22, 2012 | 12:54 PM
A BeastyDC4's Avatar
in for the write up, be looking into doing this setup as well
Old Nov 7, 2012 | 06:35 AM
shawty22's Avatar
Same. Let us know OP when you have it all set and done. Thanks.
DraginX
May 3, 2013 05:00 PM
thegatekeeper14
Nov 8, 2012 03:42 PM
wabaki
May 18, 2008 09:54 PM
