hub bore question?
Old Aug 5, 2012 | 02:41 PM
bmbf YERD's Avatar
Default hub bore question?
i know the hub bore on my car is in the low 50s i believe. the rotas im waiting to order ( because i dont have my info ) is 67mm bore. will it fit ? if not how do i make the rims fit...im sorry if this is in the wrong section but im not reeally sure where to post this question. im new to the forum . help is much appreciated guys
Old Aug 5, 2012 | 03:30 PM
ozh_hawaiian's Avatar
Default Re: hub bore question?
i believe civcs are 56.1, and I also believe that civics are lug centric, so I dont think you need hub rings
Old Aug 5, 2012 | 03:32 PM
bmbf YERD's Avatar
what do youmeen by lug centric ?
Old Aug 5, 2012 | 03:59 PM
grumblemarc's Avatar
The Grumpiest
This information is readily available by use of a Google search.
Form the Tire Rack FAQ for instance.
"Many wheels are lug centric and do not require the use of a centering ring. They are typically found on truck and SUV fitments. On these applications, the center bore of the wheel is larger than the vehicle hub diameter to allow for various hub/axle configurations that may have been an option from the factory. These wheels need to be installed with the wheel/tire assembly off the ground when the lug hardware is torqued. This allows the lugs to properly center the wheel and secure it on the mounting surface of the hub. "
Old Aug 5, 2012 | 06:32 PM
dpetro1's Avatar
you should always give the year made model and trim of the vehicle when making a post
as long as the wheel hub bore is larger than the car, it will fit. pretty sure every rota ever made will fit a honda. honda is pretty much the reason rotas were created
Zorro
Apr 5, 2015 07:38 PM
89Turbo_Angel
Jun 16, 2013 10:07 PM
J.WOLFE~v1.0
May 19, 2010 09:43 AM
JCracer723
Mar 17, 2007 05:48 PM
Top-Fuel
Apr 21, 2006 10:01 PM
