Complete b18c5 96-98 EK Swap both vins matching
I have a complete b18c5 Type R swap in to a EK with both vins matching and will come with a notarized car fax and bill of sell. The motor was just recently rebuilt about 6k miles ago with oem parts. The parts that where changed were oil/water pumps, gaskets, rings and bearings.
The only thing that was after market on the motor internally were the golden eagle head stud and the stage 5 comp clutch. everything else is oem.
Will come with complete b18c5 longblock matching lsd tranny, avid first gen ek mounts, axles, t bracket, shift linkage with poly bushings, ac compressor and power steering pump.
The only this I see bad about this swap is one of the axles click when you are turning but if you do buy it I will get you a new set
The motor runs and drives great I just been using it for my daily and never been raced or reved over 7k test the motor before you buy 4000 firm on price
Your Name
Sep 20, 2010 09:53 PM
