1991 Accord Charge Light Issues
Old Aug 5, 2012 | 06:36 AM
amerdsp's Avatar
Icon2 1991 Accord Charge Light Issues
The charge light starting flickering once or twice in a random manner. It could happen today and then maybe two days later...then in another 2-3 days..
I replaced the alternator... it ran fine for a while then the issue started again. I exchanged the alternator thinking it was defective. One day at a stop light, the light came on and the car died.
So a new alternator was put in...
The light comes on inconsistently, I am unable to tell what's causing it.
Can anyone here shed a light on this maybe?
Thank you.
A
Old Aug 6, 2012 | 07:49 PM
maystg's Avatar
Default Re: 1991 Accord Charge Light Issues
Check the connector on the alternator.Not the battery terminal but the electrical connector. Mine comes loose sometimes on my 97 ex and the light flickers, then i just push the connector back on and problem solved! until it jiggles loose again...
Old Aug 8, 2012 | 05:49 AM
amerdsp's Avatar
Could it also be something to do with the engine control module (ECM)?
Old Aug 8, 2012 | 06:14 PM
Bad_dude's Avatar
Icon3 Re: 1991 Accord Charge Light Issues
No. It's your alternator. Check the connection and go to an auto part store and let them test your alternator.
Old Aug 8, 2012 | 07:03 PM
maystg's Avatar
It might also be something in the wiring harness. If you've replaced your alternator that many times, I'd rule that out. But i would check that connector I was talking about. One time it came so loose on my car the ABS stopped working, my tach didn't work and the windows wouldn't roll up or down. Next time the light starts flickering pop the hood and press firmly on the connector, and if it clicks or the light stops flickering then you've found your problem. Good luck!
Old Aug 9, 2012 | 05:33 AM
nus_dogg's Avatar
It's gotta be a wiring issue on this one.
martik777
Jan 17, 2018 06:26 PM
dipsettkid5
Apr 26, 2016 03:48 PM
mimog3
Oct 6, 2014 09:29 AM
aalb1
Aug 5, 2013 09:47 AM
