need suggestions on how to run oil return
hey i been trying to figure out how to run my oil return line. i have a mini ram manifold and the turbo sits pretty low. any suggestion would help. i was just looking at the picture and thinking of flipping the turbo and using the bung the morosso oil pan came with. but it looks like since the turbo is too big even if i was to cut the web on the block it wont fit. the turbo is a garret 60-1 turbo 63 hot side 70 cold side.
here's a couple pictures of my set up
I ordered the drain adapter flange so that a Earl's female fitting screws right onto it elminating the screw in 45 you have on there. It raised it up enough to get an angle on there needed for the drain on the turbo side. Then just thread your 45* fitting into the oil pan and use the piece you have to connect the hose or run another AN fitting off the pan.
Drain fitting, plus you don't have to worry about leaks around the threads.
45* -10AN fitting, or you could use a 30* as well.
so i can order that fitting to fit on my turbo. then for the oil pan i can use the 45 degree fitting to bolt on the oil pan where has that screw on the oil pan? my turbo sits pretty low and theres pretty much no room the turbo sits about a quarter inch maybe less from the block. sorry i just wanna make sure i order the right fittings this time.
ok i have been searching for the drain fitting and i found one from summit racing which is a russel's fitting question is will it fit on my garret 60-1 turbo? i know the 10 an side fits .
Go to extremepsi.com They have the fittings I posted above for a decent price and they ship quick. You should be able to use your current fittings just as you said, just check before hand to make sure. Mine sits that low as well, but I have a TD05 style turbo which is even more of a pain in the ***! I have mine setup so that I unbolt the manifold/turbo as an assembly and disconnect the drain from the pan. It will give even more room to run a stock pan with a bung welded to it where ever you need it. I hated my Moroso pan, and went back to stock.
yeah im starting to hate this pan it been leaking from the drain bolt. but i played with it today and im kinda tired so imma take it to a local shop nd let him do it. since the charge pipes basically wont work without fab work also. im just tired lol.
Moroso pans and Felpro oil oan gaskets are just garbage. Use a factory pan and OEM gasket and all of your problems will go away. You WILL end up blowing that Felpro gasket out; its not a matter of "if", but "when".
I don't have any issues with my moroso pan with an oem oil pan gasket. One thing do like about the moroso oil pan is the location of the oil return
My moroso needed some touch up welding.
The drain for the turbo on the mororso is too low. Plug or weld it shut and take it to a welder. Have a an fitting welded to the pan. Have them weld it from the inside so they can get it higher up on the pan.
If your oil pan leaks at the gasket its usually installer error. You would be surprised how many tuners do it wrong.
Have you ever honestly used a Felpro gasket on a Honda before? I use Felpro on everything domestic, for my imports it has to be OEM. The Felpro pan gaskets will blow out over time due to heat. I have even tried to tighten them finger tight, they still blow on my turbo cars. Been quite a few years since I have used one, but from the picture, they look the same blue.
I have one in use right now (at least I think I am, same blue). Its about 2 years old. I reused it when I pulled my pan a few weeks ago. No leaks, no honda bond. Installed using a 1/4" torque wrench using a 2 step pattern.
i actually remember one blowing out on me before.but i already towed the car to a shop hopefully everything gets done correctly. another question i have is do i need to run a oil restrictor on my 60-1 garret. its a journal bearing
BEEYOND
Sep 2, 2004 01:08 PM
