1995 honda accord 2.2 vtec
Old Aug 4, 2012 | 03:03 PM
whiterichard70's Avatar
Default 1995 honda accord 2.2 vtec
Is my ecu bad? no spark no dome lights fuel pump dont kick on already changed main relay
it all started with no spark in the distributor. i ended up just buying a new one but still no spark. so i did research and i noticed that my check engine light does not turn off after a couple seconds when i turn on the ignition and my dome lights wont work, fuel pump not kicking on and the windows arent working either. i changed the main relay so could it be my ecu?? i desperately need to find out whats wrong because i need my car i been outta work ever since please help i gotta fix it???
Old Aug 4, 2012 | 05:20 PM
tim73's Avatar
Default Re: 1995 honda accord 2.2 vtec
Do you have a good electrical diagram? See if you can find a common circuit, which affects everything that isnt working correctly. Have you checked your grounds? Especially the ground from the engine block? What about ignition switch? Gremlins are difficult to find, but you have to be thorough and patient. Do you have any family members or friends who are good with automotive electrical systems?
Old Aug 6, 2012 | 02:40 PM
ive double and triple checked all grounds the ignition is good its really got me stumped. but that still dont explain the check engine light. would the ecu cause these problems?
Old Aug 6, 2012 | 09:32 PM
tim73's Avatar
Do you ave a good electrical diagram? Is this a stock engine? Has it been replaced or heavily modified?
Old Aug 14, 2012 | 11:47 AM
it is a stock 2.2 vtec automatic. the only modification is the air intake.
clewis3
Mar 28, 2010 02:57 PM
phagelman
Jun 23, 2008 03:39 PM
RunninEg6
17
Jan 30, 2008 10:29 AM
zeebz23
Oct 7, 2003 08:04 PM
